I have a packard bell j2422 when I switch it on the power light comes on and it starts making a noise then nothing I get nothing on monitor at all but light just stays red on power switch
  • 3,320 Answers
Could be the hard drive or it could be the power supply.
Posted on Mar 23, 2014
priyabrat
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
greg_margo
  • 1959 Answers
SOURCE: hi when i start up my packard bell imedia i get a
Assuming the monitor is fine you can try the following:
  1. Open the machine and reseat the video card; if video card is onboard try
  2. Unplug the machine and remove the CMOS battery for a few minutes; Its possible Windows didn't shut down properly and CMOS is preventing a normal startup; after replacing the battery, boot up (will probably start up in safe mode
If neither of these fixes the problem, you may have an issue with the monitor itself. Best of luck.
Greg
Posted on Jun 11, 2009
pappapumpdaf
  • 635 Answers
SOURCE: i tried reset my laptop packard bell easynote r4
Sounds like the hard drive ies and you lost your restore partition. You will probably need a new drive and hopefully you already have a restore cd.
Posted on Mar 09, 2010
Lacerz
  • 92 Answers
SOURCE: i have a packard bell imedia x2414. it crashed and
If possible, clean the inside of the laptop free from dust, then reseat and re-paste the CPU with heat sink paste.Tighten everything properly. Please do all of this when the unit is both OFF battery and OFF A/C so do this when the unit is not on ANY power.
Posted on Jun 01, 2010
KeithHL
  • 67 Answers
SOURCE: Buzzing noise on boot up, about four buzzes.
The first thing to check would be the CMOS to see if there is a setting for "case intrusion" or something to that effect. Some computers have sensor that goes off the computer's side panel is opened. I believe this can be disabled in the CMOS and/or it's just a wire connected to the motherboard that can be disconnected.
It could also be an important fan, like the CPU fan, isn't spinning fast enough which may or may not lead to an over-heated CPU.
Also check to be sure all the memory sticks are firmly seated.
If it doesn't look like any of those it could always the the power supply. See if you can borrow one for a little while for testing purposes just to see if it works.
If none of those pan out I would say call Dell support and see what they say.
Posted on Jun 08, 2010
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
Packard bell ipro yellow flashing light
Huh! Sounds like a power issue. Unplug, try cleaning out the guts in case something got in there, and retry, and again with a spare power supply if things are still bad. It would help to know whether something other than the power supply's clicking, I suppose....
Feb 13, 2010 | Computers & Internet
Packard Bell F9150 desktop power supply
open your cpu cover .
Then check your power led on motherbord blink or not also reattcha ll connection to motherbord.
check your smps fan is movinh when you switch on.
May be you have to change smps it is square box from with you attch power code.
Jul 17, 2009 | Computers & Internet
Broken stuck CD drive
Make sure it's not being held by screws on both sides.
May 11, 2009 | Computers & Internet
BIOS beep codes on packard bell home pc
You need to check your RAM, make sure it is seated properly.. this should fix the problem!
Sep 18, 2008 | Packard Bell Easy One Silver 2101 Notebook
Diamond 1200 Plus scanner
l need the drivers for diamond 1200 plus
Aug 27, 2008 | Packard Bell Packard-Bell Full Page...
PC keeps beeping when plugged in and wont start.
mite b your prossesor chip. also make sure that u have nothing pluged in to any of the usb sockets.
Jun 23, 2008 | Packard Bell iMedia SL 9553 (P660401806)...
Red power light on, making a noise but won't switch on/off
hi dear customer. add fast check the electric power and voltage. latter , cheking jumper on the main board, total main boart opening the cacing out,servising total main board.
Jan 14, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
