Question about Panasonic SCBT230 Theater System
Won't start up properly
Power on and Please Wait keeps flashing
My LCD dynex tv will turn on but keeps flashing on and off saying please wait
The fact that Please Wait appears on the screen that the power board is fine. I would unplug the tv for 4 hours and plug it back in to see if the same thing happens. It does appear that you need to replace the main board,
Apr 17, 2014 | Dynex DX-LCD32-09 LCD TV
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Door won't open
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Details about this fault has been described here.
May 15, 2012 | Televison & Video
Standby light flashes and TV won't turn on. Have to unplug it and wait for a bit then plug it back in and TV turns on. Quite a delay though. Then after TV is turned off, standby light starts...
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
Jul 06, 2011 | Samsung LN52B530 LCD TV
Dell inspiron 1501 won't boot but caps lock flashes continuosly. when i remove memory it doesn't beep
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
Jun 30, 2011 | Dell Inspiron 1501 Notebook
Keeps printing calibration page every time I turn it on
If there is any internal errors in the printer memory or if the firmware is corrupted. In order to further troubleshoot this issue, I suggest that you hard reset the printer. To do this, remove all the accessories of the printer (for example: ink cartridges, printheads, trays and the duplex unit) and power cycle it. Power cycling the printer will clear all the internal errors in the printer memory.
Please follow the steps to Power cycle the printer:
1. Disconnect the printer from the computer.
2. Turn on the printer.
3. Unplug the power cord while the printer is in "ON" state.
4. Wait for 10-15 seconds.
5. Reinstall the all the accessories removed from the printer.
6. Replug the power cord.
7. Turn on the printer.
8. Wait till printer comes to Ready state.
Check whether the printer comes to Ready state. If the issue persists, then I suggest that you download and upgrade the MMR2020W firmware in the emergency flash mode and check if the issue gets resolved.
Please click the link below to download this firmware:
ftp://sbdj:fwdownld@hprc.external.hp.com/bij1200/mmr2020w.exe
Then please follow the steps below to flash the firmware:
REQUIRES: Direct Parallel Connection (only)
1. Hold down the RESUME+CANCEL buttons while powering on the printer.
The printer will enter into reflash mode. The POWER and RESUME LEDs will be turned ON.
2. Select Start->Run.
3. In the Run box, enter either COMMAND or CMD and press ENTER. This will bring up a DOS shell window.
4. If needed, change to the directory containing the MMR2020W.FMW file. For example, if the FMW file is located in a folder called "C:\TEMP\1200FW\", type CD TEMP\1200FW and press ENTER.
The prompt should change to indicate the current directory. If the directory is located on a different drive letter, type CD D: and press ENTER to change to the other drive, where D should be replaced with the appropriate drive letter. Then change to the correct directory.
5. Type the following command to start the firmware transfer:
COPY /B MMR2020W.FMW LPT1: and press ENTER.
This will start the firmware transfer. LPT1 can be replaced if using a different parallel port (e.g. LPT2, LPT3, etc.)
6. Wait for 30 seconds for flashing to start. Flashing should follow the same sequence as described above (in step 7).
7. If, after flashing, the printer does not power-up on its own, manually power-on the printer.
(Hold the power button for a few seconds)
WARNING: Do not close the DOS window until the flashing is complete and the printer powers off (and possibly back on). Closing the window too soon could interfere with the flash process and prevent the printer from working properly. Once flashing has completed, type EXIT and press ENTER to close the DOS window.
Apr 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Cannot startup
Try removing the RTC battery (real time clock) and hopefully (for you) this is what is also keeping the CMOS memory. So, take theat out, wait about 15 minutes, put it back in, reboot and tell us your resutls.
Sep 12, 2005 | BenQ Joybook 5100U Notebook
Panasonic SCBT230 Theater System Logo
53 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
