Question about LG LSC27910 (265 cu ft) Side by Side Refrigerator
I have a LG double door model LSC27910. A rattling noise started afew days ago. It appears to be coming from the bottom rear near were the water hooks up. The sound is a rattling sound something like
Its 24 hours a day
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Sounds like some kind of vibration that you will just have to track down, also might be something caught in the fan like a card in your bycicle spokes
Posted on Mar 24, 2014
  • 66 Answers
SOURCE: Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Posted on Jan 29, 2011
  • 489 Answers
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
SOURCE: Icemaker fill leaking on new LG LFX28978SW french door refrig
Do you have the "dummy filter plug" installed and not the actual water filter in the upper left of the inside of the fridge?
Posted on Jun 09, 2011
imufo2
  • 3773 Answers
SOURCE: The ice maker appears to be working fine. However,
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 14, 2011
imufo2
  • 3773 Answers
SOURCE: Water in the bottom of
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help GO HERE:
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 04, 2011
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
I have an old zenith sentry tv, and up to know has never had any problems. Afew days ago it started making a very loud noise as soon as I turned it on. It sounds like it's coming from the right
someone needs to open it but it sounds like a part arcing which was not uncommon in those sets====you would have to decide if you want to attempt to have it repaired----some shops will not repair a set that old and unless you really want it done---I would replace it.
Mar 17, 2012 | Zenith Televison & Video
LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
Apr 22, 2010 | LG LFX23961ST Stainless Steel Bottom...
LG Refridge LFX23961st
LG LFX23961ST Support Manuals Warranty More LG
I just used the link above to get the Manuals on your LG. On page 31, they did the following CYA statements...
The defrost timer will click when the automatic defrost cycle begins and ends. The thermostat control (or refrigerator control, depending on the model) will also click when cycling on and off. Rattling noises may come from the flow of refrigerant, the water line, or items stored on top of the refrigerator .
Your refrigerator is designed to run more efficiently to keep your food items at the desired temperature. The high efficiency compressor may cause your new refrigerator to run longer than your old one, and
you may hear a pulsating or high-pitched sound.
You may hear the evaporator fan motor circulating the air through the refrigerator and freezer compartments.
As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your refrigerator.
Contraction and expansion of the inside walls may cause a popping noise.
Water dripping on the defrost heater during a defrost cycle may cause a sizzling sound.
You may hear air being forced over the condenser by the condenser fan.
You may hear water running into the drain pan during the defrost cycle.
I bolded the statement. Sounds like you are going to have to get used to the sound.
Semper Fi,
Z
Feb 01, 2018 | LG LFX23961ST Stainless Steel Bottom...
3 yr old LG TROMM DLE 5977W Dryer-loud rattling noise started about a month ago.If I press on the front of the dryer below the door it stops.Something has come loose that stopped the vibrating noise?How do...
Remove the bracket at the top rear of the dryer 6 screws
Tilt top up and forward to remove
Remove operator panel by unplugging connectors and removing screws.
Pull up and forward to remove front panel
Nov 06, 2009 | Dishwashers
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
98 xj8 rattle from rear near side???
It could be the springs on the handbrake shoes. Jaguar sell a rubber sleve to fit over the spring to stop just this noise!!
May 24, 2009 | 1998 Jaguar XJ8L
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Mar 15, 2017 | LG LFC21760 Bottom Freezer French Door...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
LG LSC27910 (265 cu ft) Side by Side Refrigerator Logo
423 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
