Question about Coffee Makers & Espresso Machines
Jura fs50 - "Decalcify".
I have had the machine for nearly 6 years and this is the first time its asked me to decalcify. (For your info, I live in a soft water area).The Jura salesman told me it may have something to do with the filter not being activated. How do I go about activating the filter under "P"? There seems to be no way of selecting "filter" ON - I'm only given an option "NO"
  • 1,087 Answers
If you read the instructions in the manual (Page 6) it describes how to descale (de-calsify) the machine. You use a vicious liquid to be used with great care. If you lost your manual go to http://www.coffeesolutions.jura.com/home_coffeesolutions_x/service_support/download_guidelines_jura_impressa_s9otc_english.pdf
Posted on Mar 23, 2014
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
SOURCE: Rinse error
How do we take the top of the Capressa Jura E8 machine off. The machine appears to be clogged and the Capresso people think that air has gotten into the machine do to a filter that was not soaked prior to putting in. Any suggestions? Thanks Mary
Posted on Oct 07, 2008
SOURCE: Decalcify
when the machine gives the signal press the bottom right hand button for 5 seconds.
it will tell you to open the knob.
before you open the knob fill the water tank with the descaling solution
place a large water receptacle under the steam wand.
now turn your knob
the machine will start to descale this can take a while
when the descale cycle is finished close the knob.
rinse the water tank out with fresh water and fill it will clean drinking water.
Press the same button on the bottom right to confirm that yo are doing the rinse cycle.
open with knob and the machine will start the rinse cycle.
when the rinse cycle is complete close the knob and load the circuit.
when descaling is over fit a new cartridge filter in your water tank and off you go with your descaled cleaned coffee machine.
Posted on Jul 13, 2009
  • 143 Answers
SOURCE: No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Posted on Sep 14, 2009
SOURCE: Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Posted on Dec 15, 2009
Decalcify jura
First run a Descale cycle from the menu (this will take several hours/overnight). Then hold the steam button for five seconds to reset the code. Good Luck!
Dec 27, 2013 | Saeco Stratos Coffee Maker, Espresso...
Is there an easier was to decalcify the capresso 3000 than taking apart the whole machine. The directions say you have to remove the auto cappuccino assembly
Yes
You should run the decalcify program with the JURA decal tablets or DURGOL. Do not use other agents.
See page 25 of user manual.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Jura Capresso C3000 Espresso & Coffee...
I rinsed coffe maker with decalcify powder, then rinsed coffee make many time with clear, fresh water but the coffee maker still reads, Decalcify/Ready For Use. Although I can make a cup of coffee, the...
Hi
I am assuming that you have a digital machine. If so, you have to go into the menu and go to "Reset Descale", push the enter button and choose "Yes" and push the button again. Then you can exit the menu and it should be gone.
Feb 03, 2011 | Spidem Trevi Automatic Espresso Machine
Keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
Jul 12, 2010 | Saeco Royal Cappuccino Espresso Machine
I am having trouble starting the decalcify program, even though the light blinks "ready/decalcify"
Had the same problem, i noticedt that there is a procedure to run decalcify anytime in the instructions book.
Turn off the machine, press Rinse button until it says Empty Tray then go go Step 2 in the instructions.
Nov 27, 2009 | Jura Capresso Impressa F7 Espresso Machine
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Declcification Program not working
Call Capresso co. at 1-800-220-5701. I had a problem and I received excellent help, a step by step walk -through which got my machine back to service. Great machine! Great help!
Jan 09, 2009 | Jura Capresso C1000 Espresso & Coffee...
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
What does Decalcify mean?
You can download the manual for free. Search for the manual.
If you want to decalcify, then you need to get decalcifying solution. The button with two circles is the decalcify mode. Press that, and the unit will go through it's automatic decalcify. There is a specific procedure to best decalcify superautomatic machines. Please search for that.
After this is done, the decalcify message will not appear. It is on a preset schedule, not an actual measurement of how much scale is in the machine.
Although you don't have to decalcify, it is recommended, especially if you live in an area with hard water.
May 14, 2007 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
48 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
