Question about Viking VCFW1000 1 HP Continuous Feed Waste Disposer
Want trun on
No power
  • Viking Master
  • 5,245 Answers
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Leak power cord
Seals are gone. Need to get it serviced or likely cheaper to buy a new unit.
Oct 04, 2014 | Garbage Disposals
Disposer wont turn off
That is the external switch that probably has welded contacts. Turn power off replace turn power on and smile it will work.
Aug 19, 2014 | Garbage Disposals
Garaabage disposal won't turn on
Check that it's getting power first, it may have jammed I am pretty sure some units have an overload cut out switch on the side to stop them burning out if jammed, check for that too.
Nov 30, 2013 | Montgomery Ward Alligetter
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
Garbage disposal wont run, power is on. Reset button pushed, not jammed.
Here's a video AKLILEABRAHA suggested as a solution to your problem from YouTube:
Fix Your Own Garbage Disposal | Disposal Repair | No Cost | Save $$$
May 05, 2013 | Waste King L-3300 Legend Series 3/4 HP...
Will not reset
can you see if any thing is in it and if not check the power
Dec 29, 2010 | Maytag DFC7500AAX 1 HP Continuous Feed...
Viking VCFW1000 1 HP Continuous Feed Waste Disposer Logo
85 people viewed this question
Top Viking Garbage Disposals Experts
Gene Haynes
Gil Shultz
ray gallant
Are you a Viking Garbage Disposal Expert? Answer questions, earn points and help others
