Question about Samsung Galaxy S Duos S7562 White Dual SIM Unlocked
Battery discharges fast
My battery discharges so fast and slow in charging. What can I do?
  • 3 Answers
Hi, first of all you should check your battery if is swell, you do that by taking it out of the phone and put on the table and try to see if it spins, if she spins that means that you have a bad battery, for more details check this video link: https://www.youtube.com/watch?v=bZMucxfNsds
If that doesn't help you then you should go with your phone to a GSM Service center cause there might be a hardware problem with you phone.
Hope this help!
Cheers!
Posted on Mar 23, 2014
Sir I have one mobile Samsung J7 2016 there is problem that its charge 92% after than its charge fast up to 100%and it discharge fast why my android version is 7.0
go to ur phone setting..then apps....
force stop the apps that u don't use... this will save your phone battery from discharge soon.
Jan 16, 2018 | Samsung Cell Phones
Gauges not working, transmission too slow, battery discharged
With engine running, put a volt meter accross battery terminals. If it reads LESS than 13 volts, your alternator is bad.
Dec 21, 2015 | 1994 Chevrolet Astro
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
Ac/heater fan slows and headlights dim intermittently on our 2003accord ex 6 cylinder
engine running or not,,??????
bad battery
or dead charging system.
rusty battery terminals.
check battery voltage parked key in pocket, see 12.65vdc.
if lower , on a warm day the battery is discharged
or at 30F it must be.12.58vdc, rested, if not the battery is discharged
or battery is bad.
if discharged , then charge it.
and fix the bad charging system.
ok you jump start car.
and the battery voltage is 13.3 to 15vdc, if not the charge system is failing, or engine RPM below 800.
if running voltage is below 13.3v the charge system is failing running.
Jan 10, 2014 | 2003 Honda Accord
Fuel relay
Short answer, your batter is bad. or is disCHARGED:
Long.:
wont crank?
no engine, cranks ,unless the starting system works.
unless pushed fast, like my car or i park on a hill and coast jump my car.(M/T tranny rule)
NO crank, is the true failure here:
slow Cranks are , bad battery , or a discharged battery , due to bad charging system or parked for 3 months or longer.
so ill assume its NO CRANK.
I turn the key TO START and the starter fails to CRANK.
the starter motor is dead. (key clue 1)
so i attach a set of jumper cables to my Caddy, running and this car
now cranks and RUNS (you left that out. above, huh? runs)
turnsover means nothing, because the engine starter turns over
and the engine can turn over and the engine can run,
once running the EFI system SUSTAINS runninng.
so there are 4 states there. (4 phases )
No cranks #1 reason to be slow , are a bad battery
so I charge that battery, and see how if it cranks , now?
it dont crank means a bad battery
it does work( crank) see how long it works.../?
if it dies again, or better, check the cars Alternator for by measuring
accross the battery terminals running , with any volt meter.
13.3 to 15vdc is a good alternator running the engine.
if NOT, the charge system is bad. (system)
On some cars the IMMO can block Cranking or for sure blocks
fueling after 2 seconds. So. watch the IMMO light on the dash.
Immo is the Immoblizer. option.
Sep 22, 2013 | 2001 Acura 3.2CL
Battery charging
Hi Patrick,
A rechargeable battery will eventually fail to accept a charge - just like your car battery.
The number of recharges a battery will be able to accept is dependent on a number of things, such as: temperature, if it is run to almost nothing before recharging (or if it is recharged after only being discharged slightly), how much of a load is on the battery and how fast (high amperage) or slow (low amperage) the battery is recharged.
Generally, cooler temperatures are better for batteries, as is using the battery almost completely before recharging rather than topping off after minimal usage, small loads are better (you don't have a choice in your GPS watch tho) and a slow or "trickle" charge is better than a fast, high current charge (you may not have a choice on this either). A few hundred discharge / recharge cycles is not uncommon - significantly less if the battery isn't cycled properly or used in harsh conditions.
I hope this helps!
Jul 01, 2013 | Bushnell Neo Plus GPS Watch
Skoda yeti battery discharge over night
dear you should test , the charging while light On, its must be 13to 14 volt ,alternator will be noisy when more charging , if there any short circuit when use head light ,
Apr 01, 2013 | Skoda Yeti Cars & Trucks
Battery fast discharge
Battery is probably at the end of its life or then there is a problem with the motherboard causeing it to consume greater amounts of power, only solution to that would be to replace the motherboard.
try with a difrent battery?
Dec 17, 2007 | AnexTek SP-230 Pocket PC
Slow or fast charge
Yes, the amperage your charging at determines charging time. The higher the amperage, the faster it charges. Your battery is rated in mAh or milliamp hours. One Ah means the electric charge transferred by a steady current of one ampere for one hour. A mAh would be 1/1000th of an amp for one hour. If your battery is a 1500mAh battery it means 1.5 amps for one hour. This charge current should not exceed the rating of the battery. It would cause possible excessive heating and possible a fire or explosion, especially on newer more volatile batteries like lithium polymer batteries. The life of the battery charge when fully charged will be similar no matter how you charged it, but slower, lower amperage charges will maintain your battery better than quicker, higher amperage charges and help extend it's life to its potential.
Dec 11, 2006 | HP iPAQ RX3715 Pocket PC
Samsung Galaxy S Duos S7562 White Dual SIM Unlocked Logo
60 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
