Question about Kenmore Washing Machines
Kenmore 25102 Lid will not unlock
My wife and I recently purchased this Kenmore 25102 from Sears. I washed my work clothes today, and the lid did not unlock at the end of the cycle. Any help would be greatly appreciated.
catriver
  • 878 Answers
SOURCE: kenmore elite oasis, lid-lock mechanism
mk, there is two ways to work around the lid. The lid lock works by magnet. If you have a large magnet laying around you can fool the mechanism and run the washer without it locking. You will have to find the spot near the center front and experiment until you get the right spot. The second way is to lift the whole top assy. About 3 or 4 inches in from each end where the top seperates from the bottom there will be a clip that you can push in on and lift the whole top. Now these clips are real strong so you need a good putty knife. Pull up on the top as you are pushing in. This way you can add your stuff while doing a normal wash. The codes are for diagnosis, testing different functions of the machine, it wouldn't do you any good for what you are trying to do. Catriver..post back
Posted on Apr 03, 2007
  • 126 Answers
SOURCE: End Of cycle alert keeps beeping
it sounds like your control board
Posted on Dec 14, 2007
  • 5 Answers
SOURCE: Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Posted on Jan 23, 2009
sotoinfo
  • 26 Answers
SOURCE: kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Posted on Nov 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
Kenmore washer lid switch
Yes all washing machines have these to prevent some one from opening lid and inserting hand or anything else while machine is spinning , once lid opens machine seizes to operate .
Oct 02, 2013 | Kenmore Sears Washing Machine Lid Switch...
We have a Kenmore Elite clothes washer model 110.2494 purchased in 2003. Every time my wife washes sheets (either 1 or two king size) they twist into a tight rope. Some research suggests that replacing...
Start the washer. Once it begins agitating raise the lid and observe the tub.
The agitator should be going back and forth.
The tub should be stationary.
If he tub is moving also,you have a bad transmission.
You may have to manually close the lid switch to watch this process with the lid open.
Mar 30, 2011 | Washing Machines
I have a Kenmore Oasis washing machine. I had to have Sears come last week to replace the computer in it. On Saturday while a load was washing the machine stopped but the lid is stuck locked. I have tried...
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2010 | Kenmore 27032
Sears Kenmore 80 series will not rinse or drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Lid Lock light stays on
You are eligible for a refund. TAKE IT ! ! This should be a learning experience.Since when did the consumer have to be come the repairman WHEN ITS UNDER WARRANTY ,C,MON NOW!!!
Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
111 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
