Turntable will not turn
Stereo is fully functional except for turntable problem. Broken belt?
  • Audio Player... Master
  • 5,158 Answers
If you lift up the mat of the deck you should see a large whole in the platter. Rotate the platter by hand and you should see if the belt is attached or not. If broken then take out the remains of the belt and measure the diameter of the belt in mm. Put that into Google with the words "turntable drive belt" and you should find a match. You might also have to look up how it's fitted.
Posted on Mar 26, 2014
Testimonial: "Thanks! I will try your suggestion."
techman
  • 3130 Answers
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Posted on Jun 15, 2007
  • 5 Answers
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Posted on Sep 18, 2008
SOURCE: aiwa stereo turntable system px-e860k
how long have you had it? could be that you just need a new belt if it keeps slipping off...
Posted on Oct 20, 2008
djproaudio
  • 515 Answers
SOURCE: I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
Posted on May 17, 2010
Toshiba Stereo Music Centre SM-D30,Turn Table, SX-N330 Speakers
Try:
http://www.vintage-electronics.net/toshiba-sr-f225-belt.aspx
If the turntable has a two-piece platter, Lift off the outer platter and place the belt around the inner platter and motor pulley.
If the turntable has a one-piece platter, lift off the whole patter, place the belt around the inner drum. There will be a hole in the platter's top through which you can reach a finger to stretch the belt so that the belt can be placed around the motor pulley as you put the platter back in place.
Aug 25, 2014 | Audio Players & Recorders
Can't get the darn to work
Remove the drive belt and see if the turntable spins, if it does the drive motor is faulty, if it doesn't then (if this is a new turntable) it's possibly got a locking device to hold the turn table steady during shipping.
Sep 12, 2008 | Sony PS-LX350H Turntable
I have an compact disc stereo system, disc,radio works. phono not working, why ?
I live in California but I do have a memorex system with the same components. My belt fell off my turntable so it didn't turn. It took a bit of patience but I was able to get the belt back on. The turntable is held down by a clip on the spindle. The belt might have to be replaced if it keeps falling off. It will do that if its been used alot. While the turntable is off, if you move the arm you can see if the turntable motor will turn on too. That would be the only other problem you can have on that unit. The repair cost might be more than what the unit cost. Just be patient and careful and you probably can fix it yourself.
Jul 19, 2014 | Memorex Nostalgia Turntable and Stereo...
Turntable doesn't play
If the turntable stopped spinning then then the turntable belt maybe broken or has slipped off the drive.
Mar 02, 2013 | Emerson Nr303tt Mini-Stereos
I recently bought a memorex 2601 M Nostalgia Turntable and the belt is broken. Where can I purchase anotherone.
They use the same belts as anders nicholson, email me and I'll get one off a broken unit. Just to make sure measure the length if you still have it. rogzjaji@yahoo.com
Aug 31, 2010 | Memorex Nostalgia Turntable and Stereo...
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
Where can I buy Pioneer turntable belts in Pietermaritzburg, South Africa?
My Auto Return Stereo Turntable , PL - 640, Quatz - Direct Drive is not playing, could you give me contact no around Pretoria or Midrand or even Johannesburg where i can send it for repairs
Apr 07, 2008 | Pioneer CDJ-800MK2 Turntable
Stopped turning
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Jan 28, 2008 | Teac SL-A100 Turntable
74 people viewed this question
 Grubhead
Grubhead
