Question about Technics SL-MC7 110-Disc CD Changer
Programming new remote
Program new remote
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
    My experience with frequently-used vehicle remotes (any make) is this:
    1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
    2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
    3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
    4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
    5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
    CAUTION
    :Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
    6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
    There are lots of options here, so hopefully something is useful to you.
    Feb 23, 2015 | 2009 Chrysler Town and Country
    Unable to program new sender to receiver. The receiver should flash three time but the diode lights up a fourth time for a period and the sender is not programmed.
    This is the procedure for remote to remote programming, try this!
    Step 1. Using a old programmed remote that is already up and running.
    Step 2. Press the button for five seconds of the new remote you want to activate and release.
    Step 3. Press slowly three times the old remote button.
    Step 4. Press the button again slowly and release control.
    Step 5. Verify that the new remote works.
    Nov 01, 2014 | Building Materials
    Toshiba Color Television 36A43 Lost the original remote and purchased a universal remote. Tried to program using all four systems to no avail. I require the universal remote code to program for this TV
    Place one remote on table, place other (new) remote facing old remote, then push the program button on new remote, remotes IR screens has to face each other to make this work. and if you've tried to program the new one before, you will have to clear the new ones memory first. Good luck.
    Jul 13, 2011 | Televison & Video
    I fried my 1400xp, so I purchased a used on on Ebay. How do I program my remotes to work with the new brain?
    To program new remotes: turn key to the on position; within 10 seconds, press and release the programming switch one time. Press the switch once more and HOLD. While holding the programming switch, press and release the lock button on the new transmitter. Once the code is learned, the programming switch can be released. Turn ignition off. Test remote. Repeat as necessary for other transmitters.
    Nov 24, 2010 | DEI Python 1400XP Remote Start/Keyless...
    Need to program new remote 3.2IR
    In your Dish Network instructions it will show you how to program your TV to the Remote
    Apr 02, 2010 | DISH Network IR Remote Control
    Have new keyless remote, how do i program it? 2006 Uplander
    The dealer should be able to program it for you. When I bought mine, the dealer could not find the keyless remote, they took another remote for a different van and they just programmed it right there and then.
    Jan 22, 2010 | 2005 Chevrolet Uplander
    95 S10 blazer 4dr power door locks inop, new battery installed in remote, all fuses good, still inop?
    1. Locate the red two wired programming connector located near the central locking control module that is located behind LH Lower instrument panel. Drop the panel and you will see the red programming connector that is not connected to anything.
    2. Inside the Red programming connector you will see to pins..
    Jump two pins with a section of wire.
    3. System should now lock and unlock doors to indicate vehicle has entered programming mode.
    4. Press any button on keyless remote once. System should now lock and unlock doors indicating the keyless remote has been programmed.
    5. Repeat step 4 to program other remote.
    6. Remove jumper wire from programming connector to exit programming mode.
    7. Test Remote(s)
    Dec 22, 2009 | 1995 Chevrolet Blazer
    New batteries but remote won't click the door(s) or trunk. Ron
    try programming the remote again, here is how u do that. if this doesn't fix the problem the remote may be defective, if you need a new one try ebay, they are very cheap to buy there.
    Note: Existing keyless remotes will be erased with this procedure.
    Existing working remotes will have to reprogrammed also.
    1. Locate the programming connector wire located in the RH trunk area.
    You may have to pull back right side trunk trim on trunk wall to locate
    the single black/white wire.
    2. The programming connector wire should have one termial in the plastic
    connector on end of black/white wire. Ground the terminal in the connector
    to a nearby bolt or trunk latch.
    Leave connector wire connected to ground through out procedure.
    3. System will now lock and unlock doors automatically to indicate
    programming mode has been activated.
    4. Press any button on keyless remote. System will respond by locking
    and unlocking doors one time to indicate successful programming.
    5. Repeat step 4 for to program any additonal keyless remotes including
    and existing keyless remotes. Do not remove ground wire between
    programming of keyless remotes.
    6. Disconnect programming connector wire from ground to exit programming
    mode.
    7. Test keyless remote(s).
    Nov 30, 2009 | 1994 Pontiac Grand Prix
    How to program a new remote keyless entry for 2002
    1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
    2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
    go without cranking engine). Wait for ignition chimes to stop.
    3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
    seconds.
    4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
    press the PANIC button ( on the programmed remote ) for 1 second and release both
    buttons. A chime will sound to indicate that the remote programming mode has been
    entered ( allow 3 seconds for chime to sound ).
    5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
    simultaneously then press and release just the UNLOCK button on the same remote.
    A chime will sound indicating the remote has been programmed. Press and release
    the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
    each new remote you wish to program at this time. Locks will cycle after each additional
    remote is programmed.
    6. Turn the ignition OFF and remove key.
    7. Test Remotes.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Nov 02, 2009 | 2002 Dodge Durango
    Technics SL-MC7 110-Disc CD Changer Logo
    47 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ben Armstrong
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
