Question about Gateway Lt3100 11.6 Laptop Led Lcd Screen
COOLING FAN FOR PROCESOR
COOLING FAN ITS NOT WORKIN PROCESOR FAN
    Champion:
  • 209 Answers
It may have reached its end of life cycle, and a new one is required; or power to the fan is not reaching it.
Posted on Sep 20, 2014
Cool processor
Try removing and re-seating processor. Check your CMOS battery for correct voltage, Reseat memory ( check Clock speeds are the same. )
Last check your power supply for correct voltages.
Feb 01, 2014 | Jetway Computers & Internet
Cooling fan 01 pt cruiser not workin
If the fan comes on only after you push it, then this indicates a worn or faulty motor within the fan unit.
Replace the fan.
Nov 14, 2012 | 2001 Chrysler PT Cruiser
Shuts off when computer gets hot
not use laptop on bed or soft thinks use hard surface thinks
if laptop agin sut off then use proccer pate on procesor also clean laptop fan neat and use cooling pad for laptop it is best
Oct 25, 2012 | Acer Computers & Internet
I have an emachines W5243, and during the start up for my windows it shuts off, any way I can fix the issue?
its restarting or its shut down?
if restarting press f8, and chose the otion whit not restart if problems, af shut down enter bios and chech the procesor temperature, if is to high, open pc case and clean the cooler and radiator on top of procesor, if is doing that from a long time is posible that the cooling paste from procesor is dry so need to be changed.
if u dont know much about hardware is better to go to a specialist or ask a friend that changed before the cooling paste otherwise u risk to do more damage
best regards
Sep 22, 2011 | E-Machines eMachines Desktop PC
My laptop fan is too noise. What happen? Expalne me Pls
you should check out that nothing is toching it while is spinning to cool the procesor!
deppending on the make of your laptop you can take the cover off and then do a visual look to make sure all seems to be correct, in another words just make sure the fan looks clean and the turn the laptop on without the cover to see if the noise is still there!!!
hope this information is help to you
Nov 28, 2010 | Computers & Internet
Fan
you may have a cooling system and not just a fan. there are numberous places to buy, but you will have to know how to take apart whole machine.
Apr 27, 2010 | HP Pavilion dv6000z Notebook
Proliant ML370T02 boot problem
Sounds like the CPU fan has gone bad and needs to be replaced
Sep 24, 2009 | Compaq (173907001) for ProLiant DL380 /...
Overclock procesor athlon 64 2800 +?
There are a bunch of guides out there to help you with the overclocking process.But bear in mind that you will loose your warranty as son as you change the frequency cycles. Also make sure that your system can withstand the excessive heat that will be generated by the processor.You should arrange some alternative cooling system like liquid coolers,Highgraded thermal insulation pastes or atleast a couple of additional coolant fans. Go through this.... http://www.hardwaresecrets.com/article/102
Nov 03, 2008 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Dell keeps shutting down
Check the procesor fan, if it come loose the temperature rises and the computer shot down to protect the procesor..or probably the procesor lost the heat sink compound.That is a compound that comes over the back part of the procesor and help the procesor to transfer the heat to the heat sink of the procesor,The heat sink is that metallic piece that you see under the fan of the procesor..probably you need to put a cap of that heat sink compound..you can get it in any electronic shop that sales repair parts for technicians.
Jul 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Gateway Lt3100 11.6 Laptop Led Lcd Screen Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
