Question about Dell F3534 Touchpad
Left button is stuck.
You can touch it barely and it activates a left-click command. It has lost it's spring back function.
graysand
  • 558 Answers
SOURCE: Left click key doesn't bounce back when clicked. Seems stuck
The key is stuck you have to be very careful if you are going to attempt to repair this.Turn the computer off and remove the battery before you attempt to repair it.Try prying it up with a thin knife blade.If this pops up and is working make sure it works as good as the other side.If not you will have to replace the palmrest.
Good Luck
Posted on Mar 22, 2010
leecom72
  • 4806 Answers
SOURCE: Inspiron 6400 touchpad woes
Hi there.
Try uninstalling the touchpad drivers and utility, that will solve the problem.
Post back if you need anymore help.
Good luck and thanks for using FixYa!!
Posted on May 26, 2009
  • 78 Answers
SOURCE: my left mouse button doesn't spring back but still
You may have a broken key, or the keyboard itself may need replacement. Find a reputable laptop technician (any decent mom&pop PC store should be able to help) to remove the key and inspect it.
-Jon
Posted on Oct 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: when i press my left mouse button it feels like it
There is not a spring....the button under the plastic cover is a self contained small button attached to a circuit board on the underside of the palm rest. Most likely the internal part of the button has collapsed. The button will still work for a short time, but it will finally fail and stay collapsed. The small circuit board has to be replaced.
Posted on Nov 02, 2009
Geekman
  • 32281 Answers
SOURCE: Left click on touchpad sunk in
I recommend you get it fixed under warranty, because if you try to fix it yourself and don't succeed then you most likely void your warranty.
The fix is usually a replacement touch pad and button assembly.
Posted on Dec 24, 2009
My product key turned to non functionality mode because I didnt entered it within 60 days. Now I cant use the MS Word 2007. How can I turn that to normal?
on the top tool bar, click on the down arrow button on the left. That should give you a drop down list of commands. click on Resources command. You will see Activate function there. click and follow the prompts. I am assuming you have got the activation code for your microsoft office.
Feb 27, 2011 | Microsoft Office Professional 2007 Full...
How do I turn on the flash on 8025
1. Touch the flash function area (lightning bolt with downward-pointing arrow) until the flash icon with the "A" shows up on the left side of the display. This activates the automatic flash.
2. Touch the flash function area again until the flash icon shows up. This activates manual flash.
3. Touch the flash function area again the eyeball icon shows up on the left. This activates the red-eye reduction mode feature.
4. To turn off the flash, touch the flash function area repeatedly until the flash icon insie a circle shows up.
This is all explained on pages 13-14 of your manual.
Jan 05, 2010 | Vivitar ViviCam 8025 Digital Camera
Light and lock buttons nonfunctional
There are certain models that had only a door bell type wall control and didn't have the lock and light functions. You may have one of these and someone has replaced the wall control with the three button model. If it did work in the past and has quit it is most certainly the logic board and is expensive to replace.
You say it is STILL stuck in the "lock" mode. If you cannot use your remotes you need to program it. Find the smart/learn button just to the left of all those white wires. Press and hold the button on a remote while you press and immediately release the smart/learn button. Do this for each remote.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Can't get underline score off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have included several solutions. The last is a procedure to RESET the device to factory defaults.
If the problem is underscore the do then I would suggest following the procedure for activating it in the hopes that it will turn it off.
Click the (symbol) key > when you see “A-I?” click the letter “ I ” > then use the right arrow key to select the underscore symbol > click enter (left facing arrow with it’s tail facing up at 90 degrees)
If the problem is underline setting being on then follow the steps to activate underline in the hopes that it will turn it off:
-Press the “Function” key
-use left and right arrow keys to toggle between options until you see “UNDL/FRM
-Then press either “FUNCTION” or the “Enter Key”
-AT ANYTIME YOU CAN PRESS “B5” to cancel out without making any changes. **Note: the “B5” key also says “clear” beside it.
All memory is lost in this unit if batteries are removed for long enough.
You can use a special RESET code which deletes all memory from the unit. The procedure is a follows:
1)Turn off the machine
2) Hold down “CODE” and “B5” at the same time. While pressing the “ON/OFF” button once.
3) Once the Machine turns back on, THEN AND ONLY THEN release the “CODE” and “B5” buttons.
ONLINE MANUAL REFERENCE http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000247/pt1180ug01caen.pdf
Jul 07, 2009 | Brother P-Touch 1180 Label Printer
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Online writing function for Digimemo L2 doesn't work
This is what worked for us: After you click on "run as administrator", you return to the online page and click on the online writing icon.
This immediately synchronizes the paper on the pad and the online page.
Also, you will notice that you can't use the digital pen to click commands in the program when the online writing icon is activated. However, you can still use your mouse or touch pad to click on commands. So, you do have to go back and forth between the pen and the touch pad when the online writing icon is activated.
Hope this helps.
Kathy
Dec 30, 2008 | ACE Computers & Internet
Left button problem
This problem of yours has a simple solution:just change the left push to on switch.desolder the original one, get a switch from the local electronic market of the same type(if possible OR another one which will b placed correctly on d pcb and which ensures that d click works)
The problem is that the spring in d switch has lost it's physical properties,which is a aging problem.
Solder the new switch,and there u go,click click click,all working fine.
May 03, 2008 | Microsoft Standard Wireless Optical Mouse
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
CRACKED SCREEN
just press the small menu button in bottom left corner, take the dial and touch it in top middle and turn just barely almost to the 3 hour position on a clock and thats ur music
Jul 05, 2007 | SanDisk Sansa e260 MP3 Player
Computers & Internet Logo
1,147 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
