Question about Powerhorse OHV Horizontal Engine - 208cc, 3/4in. x 2 7/16in. Shaft
Powerhorse horizontal shaft 208cc low oil cut off
Need fix for low oil cut off bypass.
A briggs and Stratton 800 series engine. The only serial number I can find 1ho13k50009 It says the model number is 29a-672j711. Just wondering where the oil drain is to change the oil.
vertical shaft engines can have a drain plug underneath, in the side under the filler tube or on the other side opposite the filler tube
or you can drain the fuel out , then tip it on its side and drain the oil out of the filler tube
use an oil evacuation / filler pump to suck the oil out
horizontal shaft --plugs are near the filler tube , use the pump ,or tip it on its side
Oct 02, 2016 | Troy-Bilt Tb 672 208cc Ohv Gas Powered Jet...
Why does my MG ZT two litre diesel show low oil pressure and cuts out?
The engine is designed to cut out after a few seconds without oil pressure.
So you need to establish if it's a faulty signal, or really is low oil pressure.. Low oil pressure could be down to catastrophically low oil level - top it up to the upper mark IN STAGES, 1/2Litre at a time. Choked oil filter, jammed bypass valve, blocked strainer, can also all cause the problem - lack of maintenance? Have you recently used a flushing oil in an old engine?
Also using very thin oils e.g. 0W30, in a very worn engine, will not allow the pressure to build up.
Mar 26, 2015 | MG Cars & Trucks
I HAVE 414CC POWERHORSE ENGINE THAT EVEN AFTER CARB BEING CLEANED, GAS CAP VENTED STILL AS YOU GO TO PUSH THE PEDAL DOWN FOR POWER BOGS DOWN TERRIBLY. HELP CANNOT FIGURE THIS OUT
First check for loose bolts, broken gaskets and spacers, then check to see that the choke is operating correctly, if all this checks out, the issue is going to be a bad jet in the carb, try cleaning the carb by soaking it in chemclean or other part soak cleaning solution, just soak the entire carb for about 30 min to an hour and then blow it out and off with compressed air
Oct 22, 2013 | Powerhorse OHV Horizontal Engine - 414cc,...
How to change oil pump in a v10 Triton F250 with 4 wheel drive
You have to drop the oil pan . Since it's 4wd you won't need to jack it up. The pump has 2 bolts. The shaft has a slot in it that engages the distributor so when going back with the new one be sure you line up the shaft before tightening the bolts.
Feb 05, 2013 | Craftsman 33 gal Air Compressor 6 hp...
I HAVE A19.5 42 INCH CUT MOWER WITH AUTO TRANSMISSION. IT WILL NOT MOVE WITH TH MOTOR RUNNING FOWARD OUR BACKWARDS. THE BELT IS OK AND THE LEVER TO RELEASE IS IN. IT WILL FREE WEEL NOMATTER WHERE YOU...
are the wheel / axle keys in the shafts ? make sure they are in the shafts with the wheels
provided you have correct tension on drive belt and belt is good and pulleys are all good , and spline on top of gear box input shaft is good not stipped ( as well as the pulley spline )check splines on shaft and pulley carefully
you should have movement of the variable displacement pump in the trans if all is good here ?
sounds like you may have a stuck bypass actuator in the box or the oil level has got low
and needs refilling and bleeding of air
make sure the lever is actually moving the swash plate for the transmission
if trans has a stuck or broken bypass - trans will ned opening up
let your local dealer take a look gearbox job on hydro units are not exactly easy
to fix unless you know what you are doing night pay to let local dealer repair it for you !!!!!!
cheers
Jan 23, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Low oil & smokes - 2yrs old
The piston rings need to be replaced. The cylinder might need to be bored out bigger, then put in
a bigger piston.
Hope this helps.
Oct 25, 2010 | Briggs Stratton IC Horizontal OHV Engine ...
Oil leak under the engine
If it is a vertical shaft engine then it is most likely the crankshaft seal. That requires removing the engine from the frame and removing the pump from the motor to replace the seal. If it is a horizontal shaft engine then it could be either the shaft seal or the side cover gasket. Both require removal of the pump.
Apr 29, 2009 | Garden
Powerhorse OHV Horizontal Engine - 208cc, 3/4in. x 2 7/16in. Shaft Logo
78 people viewed this question
Top Powerhorse Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Powerhorse Garden Expert? Answer questions, earn points and help others
