Question about Vehicle Parts & Accessories
Replace fuel injector o rings on a 1994 chevrolet s-10 2.2L
How to replace fuel injector o-rings
NJFIRESTORM
  • 84 Answers
SOURCE: fuel injector 2000 chevrolet blazer
the part usually runs from 30 to 70 dollars just for the injector. labor differs from place to place with the average being about 100 bucks an hour
Posted on Jun 20, 2008
  • 3 Answers
SOURCE: 1994 Chevy Camaro, 3.4, V6
where does the power wire unplug
Posted on Jan 28, 2009
delgriffith
  • 97 Answers
SOURCE: How do you replace the O-rings on the fuel injector?
to relieve pressure, there may be a purge valve somewhere on the injector rail, or if not, simply loosen one of the injectors slowly until pressure bleeds off of the system. then replace the o-rings carefully so as not to tear them.
Posted on Jun 19, 2009
tayjoejoe
  • 2194 Answers
SOURCE: 2000 CHEVROLET BLAZER 4.3 START BUT DIES.REPLACED
Anti theft system failing maybe? Read this link and compare symptoms http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on Jul 22, 2011
adadoug
  • 682 Answers
SOURCE: 1994 chevrolet z-71 pickup/ howto replace fuel pump
Yes it is in the fuel tank. You either have to remove the fuel tank or take off (raise) the bed to get to it. Many people tell me it is just as easy to raise the bed up as it is to drop the fuel tank out of it, especially if the tank has very much gas in it. Please rate my answer so I am rewarded points for it.
Posted on Feb 02, 2012
Injector o ring leak on 2.2 94 mod
Remove fuel rail, then remove the leaking injector. Replace the o-ring and the reassemble is the reversal of removal.
Mar 21, 2012 | 1994 Chevrolet S-10
MY 1998 CHEVROLET CAVALIER WILL NOT START
sound like the o rings are worn out on fuel rail when you pull the rail out slightly you are pinching the bad O ring making a seal car is starting. I would replace all O rings check fuel injector seals too, any and all vacuum lines and the seal on the fuel regulator especially if it is connected to the fuel rail.
also check and see if you are moving a wire connections when moving the fuel rail possible loose connection.
Nov 12, 2011 | 1998 Chevrolet Cavalier
Gas is leaking from my fuel rail (phlegm) on my number 5 fuel injector on my 1994 camaro
  • Park the Camaro on a flat, level surface and set the parking brake. Open the hood and secure it in place with the hood prop. Disconnect the negative battery cable.
  • Open the gas tank to relieve pressure on the fuel lines.
  • Remove the sight shield from the fuel injector with a socket wrench. Loosen the screws on the hose clamps and disconnect the fuel lines connected to the injectors. Keep a rag handy to catch any fuel that leaks.
  • Disconnect the vacuum hose and ignition coil wire, then unplug the electrical connectors. Remove the fuel injector mounting bolts, undo the retaining clips and remove the fuel injectors.
  • Put a thin coat of engine oil on the new fuel injector's O-ring. Place the O-ring in position, install the new fuel injectors and secure the retaining clips. Install the mounting bolts with a torque wrench set at seven pounds.
  • Plug the electrical connectors back into the fuel injectors. Reconnect the vacuum hose and ignition coil wire. Connect the fuel lines and tighten the hose clamps with a screwdriver to secure them in place. Bolt the sight shield in place with a socket wrench.
  • Place the gas cap back on. Reconnect the negative battery cable
  • Dec 06, 2010 | 1994 Chevrolet Camaro
    How do i remove the fuel injectors on a 1994 camaro 3.4 v6 im trying to replace the intake manifold gasket and cant get the injectors out of the fuel rail
    You can generally remove all injectors with the fuel rail as a unit. Just unplug them from the wiring harness and pull up the fuel rail. The injectors are just pushed in with o-rings.
    Aug 28, 2010 | 1994 Chevrolet Camaro
    I have a 94 blazer 4.3 fuel injected and it is pumping gas into the oil
    how often do you idle this blazer. if you idle alot this this adequetly lubricate the cylinder walls and what happens is "fuel wash", which then progressively wear the cylinders,rings,and piston ring lands and grooves. you may also have a throttle body/injector problem causing over fueling. any sign of smoke?
    Feb 11, 2010 | 1994 Chevrolet S-10 Blazer
    Fule in oil they clame it is a bad fule injectors...???
    On a v6 the fuel injector tubes leak under the manifold. Some call it a spider.
    Sep 25, 2009 | 1994 Chevrolet S-10 Blazer
    1994 chevy fuel problem
    The last pieces in the chain are the fuel regulator and the injectors. The regulator is inside the throttle body, but it sounds that maybe the injectors are not firing. For nothing else, check out the connections to the injectors. Possibly they are clogged. Try a few treatments of injector cleaner.
    Jul 29, 2009 | 1994 Chevrolet K1500
    How to replace the fuel injectors on a 2002 Tahoe?
    To Install:
    1. Lubricate the NEW fuel injector O-rings with clean engine oil.
    2. Install the O-rings on the fuel injector.
    3. Install a NEW retainer clip on the fuel injector.
    4. Install the fuel injector in the injector socket with the electrical connector facing outward. The retainer clip locks onto a flange at the fuel rail injector socket.
    5. Install the fuel rail.
    NOTE: Use care in removing the fuel injectors in order to prevent damage to the electrical connector pins on the injector and to prevent damage to the nozzle. Service the fuel injector as a complete assembly only. The fuel injector is an electrical component. DO NOT immerse the fuel injector in any type of cleaner.
    Mar 29, 2009 | 2002 Chevrolet Tahoe
    are you sure that the fuel injectors were clean when you replaced the o-ring or maybe there is still a piece of o-ring left inside the fuel injector port if this still does not work then replace o-ring with two rings a smaller o-ring and a larger one
    Aug 27, 2008 | 1994 Chevrolet Camaro
    Gas leak
    You just replace the O rings and check if its leaking ,before doing replacement check for blocked injectors which is causing this problem:
    Please click on this link:
    http://www.autozone.com/addVehicleId,1954802/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c1528003bbf3
    Good luck..
    Aug 19, 2008 | 1994 Chevrolet Cavalier
    Vehicle Parts & Accessories Logo
    16 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
