Vst voh 952dv
Its on mute and can't here anything as well as the remote not commecting
Sony Bravia stuck in mute
The fault is with its main board itself. It will be best to get this set repaired by skilled technicians. This is not a user repairable one.
Aug 24, 2012 | Sony Televison & Video
I am having a problem getting sound out of a program called cubase 5
In cubase go to "Devices", there select "Device Setup", in the Device Setup windows go to "VST Audio System", on the top right you will see the "ASIO Driver" drop down menu, click it and select your sound card from the list. Also take a look into VST Connections.
Jan 10, 2012 | HP dc5000 PC Desktop
When mute the system I lose all sound and get get it back
I assume you mean you CAN'T get volume back afer hitting MUTE on the remote. I also assume you have tried to hit MUTE again, and INCREASE VOLUME and they also do not work. Easiest first try is to change remote batteries and clean battery contacts, and cross your fingers. If you are using a programmable Universal Remote, you may need to try an alternate programming code ... sometimes the wrong code allows some functions to work and not others. If you can get your hands on a second remote, try it again and if it works, then your first remote is broken. If not the remote, as a guess it sounds like the mute circuit is latching-up (the electrical equivalent of a stuck switch). This can be caused by anything from a bad transistor (or IC) to a bad capacitor to ground on the mute circuit. If you can locate the mute circuit on the board you can try replacing these parts (a transistor or capacitor are probably inexpensive enough to try - an IC is probably not worth it, and you will live without the convenience of a working mute). You can also try to reheat the solder joints on the circuit board for the Mute Circuit section of the board -- just re-liquify the solder and get a shiney connection. If you have a bad connection or cold solder joint it could cause the problem. Obviously, DO NOT TRY THIS IF YOU DON'T KNOW HOW TO AVOID ELECTRICUTION - sets hold a pretty stiff charge even after unplugging them, and can really hurt if you get zapped.
Aug 29, 2011 | Televison & Video
I have an old Technics SA-GX300 receiver that works fine except that the screen indicates that muting is on (still produces volume but at much lower levels). I lost the remote to the receiver. Is there...
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Jul 08, 2011 | Technics SA-DX850 Receiver
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Hello
PLZ UNINSTALL NUENDO FIRST. THEN INSTALL MOTU DRIVER. NEXT POWER MOTU.
NOW YOU SETUP NUENDO VST AUDIOBAY FROM DEVICE SETUP. CLICK VST AUDIOBAY AND SWITCH IT.
NOW YOU CAN SETUP MOTU AUDIO.
OK
Apr 30, 2010 | Steinberg Nuendo 3 for PC
Someone help me!
A relatively straightforward answer is that the AT4 is not VISTA compatible.
AT4 is not VISTA Compatible and has issues with XP 64bit. It is only guanteed to work with
Its compatibility list is as follows
DirectX
on Win 98, ME, NT, 2000, XP
@ V4.3.9
VST Mac
on Mac 10.2.6 or later
@ V4.3.9
VST PC
on Windows XP
@ V4.3.9
Oct 16, 2009 | Antares Auto-Tune 4 TDM Production Suite
Cubasis vst version 5 serial number
If you go to
http://www.steinberg.net/en/support/steinberg_support_creative_tools/cubasis_vst_faqs.html
you will find a serial number for Cubasis VST version 5.
Hope this helps.
Feb 15, 2008 | Computers & Internet
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
 Grubhead
Grubhead
