Question about Shark SV75 Cordless Pet Perfect Hand Vac
Motor smells like it's burning
Brand new and smells like motor is burning and won't turn on the second time I tried to use it
My vacuum smells all the time like someone threw up. It stinks the whole house. It is not a burning rubber smell as the smell is there even if not using the power head.
Have u got dogs? if its smelling bad "we are what we eat" and so is the vacumn.try a carpet powder "shake and vac etc." Empty after each use
Apr 07, 2017 | Vacuums
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
Jul 23, 2012 | Vacuums
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Hoover Wind Tunnel U5720-950
be sure it has a new bag and fillter, or try running it on a clean surface with the door off. if it still has a burn smell and only runs a few seconds the motor is probably bad. expensive and difficult to access. kitty litter has moisture in it and the vac motor is strong enough to pull the moisture out and draw it through the motor which will damage the commutator. kitty litter (and plaster dust) are stone dust composed and will pass some material through filters in to motors. for such jobs you should use a shop vac style machine , since they have a bypass motor that doesn't pass material through it.
Jun 10, 2008 | Vacuums
Burning Smell coming from the moter
This could be a motor problem. There is always a slight blue arcing that occurs when an electrical motor runs and can be visible through the exhaust vent, but any excessive arcing indicates a problem. If the carbon brushes are sticking, this will cause excessive arcing and can be corrected by an experience service person, but if there is any electrical failure, the motor would have to be replaced. There are no parts available for these motors and the expense of replacing an armature (the likely culprit) would be more than the motor. This could also be as simple as a worn belt, but usually, belts will not produce the smell your describing. When a motor is burning out, it will produce an acrid odor that will linger for a long time.
Feb 23, 2008 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Smell
hi
check there faq page from here http://bissell.com/Search/FAQ.asp see if they can answer that ?
riz.
May 31, 2007 | Bissell 6594 PowerForce Bagless Upright...
Shark SV75 Cordless Pet Perfect Hand Vac Logo
24 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
