Question about Harman Kardon AVR 70
Picture is not in synch with audio
How do I synchronise the picture with the sound
Good sound but scrolling picture with diagonal lines. Zero quality.
Check the vertical synchronisation section. Either the set lose vertical synchronisation signals, or the vertical oscillator is oscillating out of frequency. The work is a skilled one, and you must have through knoledge in electronics to follow.
May 14, 2012 | Zenith Televison & Video
In movie mode, my sound is "in front" of the movie
this may not mean much, so look really hard at the instruction manual but If the audiostream was recorded at 48,000Hz, change it to 44,100Hz... but if that way over your head try this easy way: in the menu look to find image quality and audio quality, when you are here either do as i have asked above or change your visual settings from high to normal, also if you have any of those menu items up on the lcd when you are taking the clip get rip of hem, as in my experience they slow down the processing power of the IC and these IC are made to process pixels not sound, so eventually after 40frames there is an overlap. good luck by the way!
Oct 04, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Guitar goes out of Synchronisation
You might have better luck on another forum, this one is for TV's
Feb 07, 2018 | Edirol FA-66 (EDIFA66) Audio Input
Units will not stay synchronised
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
jeonatumi4
Jan 03, 2010 | Nintendo Wii Console
Unable to synchronise wi fit board
that somtimes happens if you want it to synch press the synch button on the wii and the balance board for about 5-10 secs then once there synched press (A) on the wii controller and theat should do it thats how i got mine to work Hope this helped :)
Aug 29, 2009 | Nintendo Wii Fit for Wii
Synchronisation problems
try to change the sound setting of your reciever.. try all options of sound setting..
Dec 27, 2007 | Onkyo TX-DS777
Can't synch notes or contacts from outlook to Palm Tungsten C
Right click on system tray icon of synch (Red and Blue Arrow) Select custom and see what you are synching
Sep 12, 2005 | Palm Tungsten C Handheld
Hotsynch manager does not list mail as a synch task
When you first install Palm Desktop, you have a choice of synchronizing with Palm Desktop or with Outlook.
It sounds like you chose Palm Desktop.
You have to uninstall Palm Desktop and Reinstall it.
There will be an option to synchronize with Outlook/Versamail so make sure to choose that.
Sep 11, 2005 | Palm Zire 71 Handheld
22 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
