Question about 2002-06 Nissan Altima Vehicle Speed Sensor for L4 2.5L with Automatic
How to know if speed sensor is bad nissan altima 05
How to know if speed sensor is bad and how many is there?
    Genius:
  • 1A Auto Parts Master
  • 2,494 Answers
Undo the bolt holding the unit into the gearbox and check the drive gear,s not stripped.
Posted on Mar 17, 2016
I need to know what code 1715 means on my nissan altima
Trouble Code: P1715
A/T Primary Speed (Input) Sensor Circuit Malfunction
Possible Causes:
CAN bus circuit from the TCM to PCM is open or shorted Input speed (primary) sensor circuit is open or damaged TCM has failed
Mar 27, 2013 | 2008 Nissan Altima
I have a nissan altima 05 3.5L engine service light just came on and my scanner read these codes P0722 and p0717 p0462 and p0500 are these things i can fix on my own?
CODE PO462 FUEL TANK LEVEL SENSOR VOLTAGE LOW. CODE PO717 TURBINE SHAFT SPEED SPEED SENSOR NO SIGNAL. CODE PO722 OUTPUT SHAFT SPEED SENSOR NO SIGNAL. CODE PO500 VECHICLE SPEED SENSOR CIRCUIT MALFUNCTION. SOUND LIKE YOU HAVE TCM ECM PROBLEMS GETTING TOO MANY CODES. COULD HAVE LOOSE GROUND WIRE TO THE TCM AND ECM.
Aug 06, 2011 | 2005 Nissan Altima
I have a 05 nissan altima with the code p0037 and p0037 pd. what do the mean and how can i fix it?
Bad o2 sensor heater circuit. Check for damaged wiring to sensor first, if undamaged replace sensor.
Mar 06, 2011 | 2004 Nissan Maxima
Where is the speed sensor located on a 2005 nissan altima?
if you have a po725 fault code"engine speed signal" this would be an indication of a bad crankshaft sensor.the good news is it's only 50.00.the bad news is it is a pain the *** to replace!it is located on the firewall side of engine block above oilpan rail by trans bell housing.i replace them from the top reaching down but its all feel...cant see anything.if its the vehicle speed sensor in the trans your after this is about 150.00 and is located in final drive section of trans right above the drivers side inner c/v joint.much easier to replace.hope this helped...let me know.
Feb 21, 2011 | 2005 Nissan Altima
Estimated cost for replacing a crank shaft sensor in 05 nissan altima? $190 sound fair - mechanic quote, 45 min. fix
Yes that is a fair price for this job. How do we know thats what the problem is?
Quinn
Jan 22, 2010 | 2005 Nissan Altima
My 2003 nissan altima has jerky shifting and shuts off randomly
Change the Throttle Positioning Sensor.
Clean the Mas Air Flow sensor with carburator cleaner, carefully.
Vitally
Sep 14, 2009 | 2004 Nissan Altima
Locating the engine speed sensor on an 05 altima
Its on the right front of the transaxle near the right axle flange.
Aug 02, 2009 | 2005 Nissan Altima
Service engine soon light came on...the diagnostic said that it's my speed sensor. where is that in an '05 altima 2.5s and can i buy it anywhere other then a dealership?
VSS (Vehicle Speed Sensor)? Is its that then did your ABS light come one? You have 4 sensors, one per wheel located on the back side of the knuckle/spindle
Apr 23, 2009 | 2005 Nissan Altima
2003 nissan altima 2.5s transmission rough shift
Probably sensors! I have already replaced the crankshaft positioning sensor once, nissan replaced it once under recall and now it is bad again! Plus my speed sensor is bad too! Go to any part store and get diagnostic test ran, it will tell what sensors are bad.
Sep 25, 2008 | 2003 Nissan Altima
2002-06 Nissan Altima Vehicle Speed Sensor for L4 2.5L with Automatic Logo
37 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
