Question about Ztech Golf
Hat clips only
Source for hat clips magnetic only ? Have several hats and ball markers. Savannah / king & bear.
SOURCE: how can i installed driver of sata hdd for linux red hat
Hi i am mansur alam.
I have a same problem. when i installed Red Hat Linux Enterprise Edition in SATA HDD 160GB.
Shows error No hard drive have been found.
How Can I Install Because RH Linux 4 is not detect my SATA HDD
my Email : mansur.alam30@yahoo.com
Posted on Aug 04, 2008
SOURCE: DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Posted on Nov 13, 2008
SOURCE: Blue Hat Bank
Type in the code 1234 ENTER then enter your child's new pin.
Pax, Moncia
Posted on Jan 25, 2009
cpt_cavman
  • 69 Answers
SOURCE: Hi-Hat not always working with controller
youll need to change the sensitivity on the brain and all will be good
Posted on Jun 23, 2009
  • 133 Answers
SOURCE: Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Posted on Aug 06, 2009
Different between white hat and black hat seo?
There is main point is a Whit hat SEO and Black hat:
White hat SEO is Best way ... But this is time taken and log time stability
When, Black Hat SEO is a un-natural way Like Stuffing of keywords, Copy Content, domain parking and S ping... etc. it's technique used then Spam works Like
Jul 31, 2015 | 2007 Honda Accord Sedan
Tip
How to wear a hard hat properly
With so many different brand of hard hats there are all kinds of rules and for how a hard hat is meant to be worn. Never fear there are a few points that they all agree on and these are the ones that you should always keep in mind when you head off to work.
First you want to make sure that the suspension straps on the inside of the hat fit properly. You can adjust them by moving the pin to different holes much like you do to change a belt. The plastic of the hat isn't supposed to sit on your head like a regular hat. There has to be space between your head and the hat to help 'cusion' the impact of something hitting your head.
The ******** the back of the hat, one that sticks out lower should be tight on the nape of your neck. This strap helps in keeping the hat in place.
If your hard hat has a chin strap make sure that you have it adjusted properly because this will keep your hat on your head when bending over or looking up. The chin stap should sit on your chin suggly and not be looped under your chin in the space between your chin and your neck.
If you are finding it difficult to get the hat to fit properly never use fillers to make it fit better. You might just have a hat thats not the right size for your head. Using a filler can change the effectiveness of the hat and make it dangerous to use. Its better to ask for a new one then find your own solution.
on Nov 21, 2013 | Work Safety
Three men are facing a wall in single file. The furthest is #3 and he can see #2 and #1's heads. The man in the middle, #2, can only see #1's head. The closest to the wall, #1, cannot see...
#1 says he has a blue hat.
If #3 sees two red hats then he knows he has a blue hat. Since he says he does not know the color of his hat, #1 and #2 do not both have red hats. They may both have blue hats, or one a blue hat and the other a red hat.
If #2 sees a red hat then he knows his hat is blue since #3 did not see two red hats. Since he says he does not know the color of his hat, #1 must have a blue hat.
May 29, 2014 | Office Equipment & Supplies
Sides of hat are wrinkled. How do I straighten and stiffen?
how about heat up a soup spoon on gas range or other heat source and then iron your hat wrinkles with spoon when spoon cools heat it again or go to a hat store the person should be able to fixya
May 18, 2014 | Office Equipment & Supplies
Where can I buy unique hat feathers?
The Carnmeal website has hundreds of different hat feathers to choose from.
http://www.carnmeal.com/Hat-Feathers.asp
Mar 04, 2013 | Clothing Accessories
I need to buy party hats for our kindergarten. Any suggestions of places that are not too expensive?
I like the Dollar Days site as they have a good range but have wholesale amounts or quite competitive prices.
http://www.dollardays.com/wholesale-party-hats.html
Although their hats all seem to be themed ie Pocohontas.
Hope that helps.
Feb 25, 2013 | Event Planning & Celebration
What can window does it take
I have loaded windows 2003 server on this but the following OS are supported:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279705&lang=en&cc=us&prodTypeId=15351&prodSeriesId=316537&taskId=135
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows Server 2003
Novell NetWare 5.1
Novell NetWare 6.0
Novell NetWare 6.5
OS/2
Red Hat Enterprise Linux 2.1 (x86)
Red Hat Enterprise Linux 3 (x86)
Red Hat Enterprise Linux 4 (x86)
Red Hat Enterprise Linux 5 Server (x86)
Red Hat Linux 7.2
Red Hat Linux 7.3
Red Hat Linux 8.0
SCO Open UNIX 8
SCO OpenServer 5
SCO OpenServer 6
SCO UnixWare 7
SUSE Linux Enterprise Server 7
SUSE Linux Enterprise Server 8
SUSE Linux Enterprise Server 9 (x86)
Dec 25, 2010 | HP Compaq ProLiant ML350 G3 Server
How to install red hat image and how to make a bootable dvd of redhat linux image
Red Hat has gone commercial, it costs money for their iso's
However, you can get the latest bootable Linux Ubuntu 9.4 distro at On-Disk.com for $5.00, sent to you in the mail, it will work perfectly for what you need
Jul 11, 2009 | Computers & Internet
Dashboard lights
This might light when your sunroof is opened if it has one. Reminding you not to wear a hat while driving with the sunroof open.
Dec 31, 2008 | 1995 Jaguar XJ6
Golf Logo
61 people viewed this question
Top Ztech Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Ztech Golf Expert? Answer questions, earn points and help others
