Question about Maytag Neptune MAH7500A Front Load Washer
Water just keeps running in the machine
Water keeps coming in when the machine starts to wash
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Cold water keeps on running
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Apr 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kennmore washing machine Model 11026722693 water level overflows and won't stop filling....
Unplug you washer, if water still runs into you machine, you have a bad water valve. If it does not your selector switch is bad. This is the switch where you set the size load you want to wash. If you will go to www.partselect.com This is their part number PS342529 for your part. enter it in the box and this will bring up the part you need. From there you can order it. Good luck.
Oct 22, 2009 | Kenmore Washing Machines
The water continues to run into my Maytag Ensignia after the cycle is complete
Oct 05, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing machine continues to fill when starts
Oct 01, 2009 | Washing Machines
Water won't stop running even when we turn the machine off it slows a little. i have to turn the water off to stop the flow of water.
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine does not stop filling with water. Will
Sep 30, 2009 | Washing Machines
Maytag Neptune MAH7500A Front Load Washer Logo
12 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
