Question about Grandstream GXP2124 4-line Enterprise HD IP Phone
VOICE ECHO my voice echos when I am talking on the phone
I have a echo in my iphone when talking
it is may be not your problem. Problem Belongs to whoom your are talking with. He/She may be useing loude speakers. Or it can be problem of your mobile Service provider. Upgrade your cellphone iOS.
Apr 06, 2014 | Apple iPhone 4S
Bad echo in ear piece while talking
You can try adjusting the volume and see if any results. Try to verify if it is a hardware defect by using a Bluetooth piece and if you get better results.
Nov 08, 2013 | Plantronics CS530 Wireless Headset System...
Bypass echo board on2527 galaxy still talk
To disable the echo, the simplest method is just cut the jumper wire from the power supply section to the switch.
To bypass a faulty echo board, connect a sheilded jumper from pin of IC1 to the Voice position of the the connector/R63 at J6 . Isolate the echo board completely by removing one side of R39 and R68
Feb 19, 2012 | Radio Communications
Echo occurs on voice chat
just down the mic volume and see als run the sound diagone test.
Sep 08, 2009 | Logitech QuickCam Communicate STX Personal...
T7316 Dropped calls and voice echo
How are your lines coming in to your phone system?
Generally you get an echo on VoIP lines not set up correctly.
T7316 should not give echo, as it is a digital phone.
May 29, 2009 | Lands Phones
MIC
my 3110c's when i have call to other phone,what i m talk,my voice is echo to me,but out going voice is not going to another phone. so how can i solve this problems
May 19, 2009 | Nokia 3110 Cellular Phone
Echo while talking to some other phones
U see echoing isnt d problm f the phone... It`s the pbm of d service providers (yr network)....dnt worry they usually get repaired when the correspondn frequencies are altered.....
Apr 12, 2009 | Vtech Cordless 6041 Phone
My Philips SE 450 sounds awful. I hear my own voice in my phone as I talk. It is like an echo.
you may have to enable a feature called voice enhancing on your voice, the echo is sometimes caused by feedback from various sources. it should appear as a VE symbol when you have it turned on, this helped me greatly when I was going through the same prob, it also makes the phone reception sound better on both ends. you may have to call the phone company to check to see if they installed the lines right in the first place. Also if your phone has the ability to change channels you can keep switching channels until you find one that sounds better to you.
Nov 13, 2008 | Lands Phones
Echo while talking on phone
I have a panasonic cordless 5.8ghz I hear an echo when I talk to someone . Can you please tell me how to get rid of it
Jul 07, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Grandstream GXP2124 4-line Enterprise HD IP Phone Logo
20 people viewed this question
Top Grandstream Lands Phones Experts
ray gallant
spy1309
james laughton
james laughton
Are you a Grandstream Lands Phone Expert? Answer questions, earn points and help others
