Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Stuck on rinse cycle
Wash cycle works fine then it gets stuck on rinse and just a low a low buzz from the controle panel. I can move the selector to spin and the spin cycle works fine. I changed out the timmer. The problem still the same.
  • Whirlpool Master
  • 3,361 Answers
Your water valve is bad or the cold side of the valve is stopped up with sediment. Clean the water valve inlets. If that does not correct the problem, replace the water valve.
Posted on Jun 14, 2009
Whirlpool washer bad timer
it very much sounds that the moving parts the timer are worn or seize recommend new timer
Nov 23, 2017 | Whirlpool Washing Machines
I have an rwt350aw that worked fine on Sunday. However, went to use it last night and it filled and agitated fine during the wash cycle, but when it hit rinse, the tub wouldn't drain and there was a hum...
Sounds like a relay sticking or a pump not turning over ,it fills fine so I would say it is the relay the switches the rinse cycle on. Relays go bad alot and are replacable. Take cover off and recreate to find buzz BE CAREFUL AND DONT TOUCH ANYTHING .
Feb 17, 2011 | Washing Machines
Doesn't Wash Clothes, But It Rinses Clothes
hello. i can help you.
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jun 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Washing machine not rinsing
Set your machine for warm wash warm rinse.
If it works OK.
Replace the water inlet valve.
Feb 14, 2009 | Kenmore 22422 Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
175 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
