Question about Homedics Pool & Spa
Heater stopped working in bubble bliss model bb1
It doesn't heat up. is there a fuse or reset
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Maytag 7500AYW electric dryer stopped working
Hello, ramonc I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
It worked fine the last time I used it, now it will not make bubbles. What should I do?
Review- Deluxe Bubble Bliss Foot Spa by Hometics ...
? 5:14
https://www.youtube.com/watch?v=LUBHAmA0y3A
Apr 17, 2014 - Uploaded by Calla
I love this bubble spa, its great for anyone who is on their feet all day, Its ... my machine quit working for the bubbles ... My mom bought one yesterday, but it does not bubble. ... make them a little larger so you could submerge your whole foot in ... I'm curious if you've ever used essential oils during your foot ...
The Next Best Thing to a Jacuzzi - Epinions.com
www.epinions.com/.../HoMedics_Bubble_Spa...2/.../130896793220
Jan 29, 2016 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
How can I fix the heating element?
Here's this product instruction manual, it may help you:
http://www.homedics.com/media/documents/homedics/instructionbooks/FB-50_IB.pdf
You can also go to their website at: http://www.homedics.com/bubble-blisstm-deluxe-foot-spa.html and try to contact their support
Mar 01, 2013 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
HAVE NO HEAT HAVE CHECKED ALL FUSES CHECKED ANTIFREEZE FINE NOT SURE WHAT TO CHECK NEXT
Most likely your blend door. The door behind your dash that controls weather your A/c or your heater is working. This is assuming you still have a/c. Even if your car doesn't have a/c you will still have blend door so that you can stop heat from coming into car in summer.
Oct 28, 2012 | 2000 Oldsmobile Bravada
Air bubbles in the coolant system causing the car to run hot
If you are seeing air bubbles, then the cooling system still has air pockets in it. Loosen the overflow cap and leave it that way for a few days while you drive.Keep the heater turned on at the max heat level. Roll a window down if necessary. Check and top up the overflow bucket daily and top up as necessary. The bubbles should disappear after a few days, then you can tighten the cap. This should also solve your no heat problem. Once the bubbles are gone you can tighten the cap.
If the problem doesn't fix itself in a week, you should have the car looked at for a possible bad head gasket, which would force air into the cooling system. Hope this helps.
Feb 20, 2012 | 1999 Cadillac DeVille
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Jan 19, 2010 | Heating & Cooling
Check engine light - sensor 2
Replace the sensor. Common problem. The heater burns out in them.
Jun 24, 2009 | 2000 Dodge Durango
Optimus H-4438 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Electric Water Heater Problem
When an electric water heater fails to heat water, either the power to the water heater has been interrupted or there is a problem with the controls or the heating elements. 1) Be sure electricity is being delivered to the appliance. Check the main switch on the water heater and the circuit breaker (or fuse) that serves the water heater. 2) Check the high-temperature cutoff in the water heater. Open the panel, and push the reset button. 3) If these steps don’t solve the problem, call an appliance repairperson.
Aug 27, 2008 | Stiebel Eltron TEMPRA 12 Tankless Water...
Pool & Spa Logo
69 people viewed this question
Top Homedics Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Homedics Pool and Spa Expert? Answer questions, earn points and help others
