Question about CAS CL5000 Label Printing Computing Scale
Print button not work
Print button its not work and next to print button clear mean c button to its not work
How to clear pending print que HP LaserJet Professional P1606dn
Hi there you clear the pending print on the computer next to the watch you can see the pending prints and there you can abort the print. I mean it is right click on the printer and choose abort the print..Hope it helps
Sep 12, 2014 | Office Equipment & Supplies
My problem is error 5100
This is usually a carriage error, meaning something is or was jamming the cartridge carriage at some point. Check for stuck paper anywhere, then try reset the printer to see if the error clears.
You can try to reset it to factory mode by following the steps below:
1. Turn off the printer.
2. Press and hold the ON button while pressing the Stop button. (DO NOT release both buttons).
3. When the Power LED lights in green, while holding the ON button, release the Stop button. (DO NOT release the ON button.)
4. While holding the ON button, press the Stop button 2 times, and then release both the ON and Stop buttons.
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, until it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
If that doesn't work contact Canon or your local service depot.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 06, 2012 | Canon Office Equipment & Supplies
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
Us.mg1.mail.yahoo.com is stuck in my printer que and I cannot cancel or delet it nor can I print anything else
Unplug your printer and leave it unplugged for at least a minute. Also reboot your computer. It will clear the printer queue!
May 05, 2011 | Yahoo Mail
Error 5100
Try to update your software here:
http://software.canon-europe.com/products/0010231.asp
If that doesn't work contact Canon or your local service depot. Good luck.
Feb 24, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
Canon cp330 printer otom part of picture not printing color properly
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check.
Steps:
1. Go into Microsoft Word.
2. Create four small rectangles.
3. Colour one of them black, another pink, the next turquoise, and the last yellow.
4. Print!
5. If all of the colours have come out clearly, it means you have enough of each colour. If one or more are not clear, you need to change them.
6. Save the file in My Documents to run whenever you need to test your printer cartridges.
7. Run occasionally to work printhead if printer is not used very often.
Tips:
1. To create rectangles in Microsoft Word, bring up the Drawing toolbar on "View" then "Toolbars", and press the rectangle button. To colour them in, right-click on them and choose "Format Autoshape" then choose the colour for the fill.
Dec 10, 2008 | Canon CNN-CP330 Thermal Photo Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
CAS CL5000 Label Printing Computing Scale Logo
Top CAS Office Equipment & Supplies Experts
jasbo
jasbo
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
