Question about Iomega Computers & Internet
Iomega 31817400 beeping
Beeping noise when connected to tv
Beeping often indicates a power problem. Try a different usb cable.
Sep 04, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
My pc doesn't recognize my iomega external drive. when i turn the drive on it beeps.
Does it work on any other computer?
Beeping normally means a post code error
Nov 28, 2010 | Iomega 1.5TB Desktop USB Hard Drive
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
My iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Jan 11, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Nov 26, 2009 | Iomega (33654) Limited Edition 500 GB USB...
I can't access my fiels on my iomega drive, it
Is is getting detected . If not the solution is to try for a new one. the internal chips may be damaged.
Sep 03, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Beeping noise
Check the drivers for the hardware.
Jun 12, 2009 | Iomega Silver Series 320GB 3.5 External -...
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Computers & Internet Logo
51 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
