Question about Nordic Track NordicTrack T6.3 Treadmill
Brand new and will not operate
Brand new treadmill that will not operate. It comes on but will not operate
Why is error 3 coming up treadmill works for a few seconds then stops and error 3 comes on
hi,
You didn't mentioned the brand of the treadmill. Its necessary to ad the make and model number, then only you someone would be able to help you sole the problem.
www.electro-medical.blogspot.com
Aug 25, 2015 | Exercise & Fitness
Everything working except the belt
do you have the magnetic tag attached to you and the machine? it prevents operation unless its attached.
Jan 15, 2014 | Golds Gym Trainer 410 Treadmill
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
E09 code on profitness treadmill
Return it. Get your money back. Buy a real treadmill.
Jan 13, 2018 | Exercise & Fitness
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    My treadmill is brand new and not coming on
    Hi ispeaktobefr,
    Please check the following:
    1. Please make sure that the battery is fully charged, because it won't work if not.
    2. If the motor turns slowly then your motor is ok, if not the motor is bad and would need to be replaced.
    3. If the motor is ok then the motor controller ( the board with the metal ) is malfunctioning and would need to be replaced.
    4. You may also check the fuse.
    Hope it helps.
    Thank you for using FixYa.
    Jul 14, 2011 | Weslo Cadence 60 SE Treadmill
    Belt wont start on a brand new Sole F80. Motor
    It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
    Mar 12, 2010 | RTO Sole F80 Treadmill
    My proform belt wont start
    i dont mean to be rude , but if its brand new call the company that built it and they should be able to help you. should be able to troubleshoot over the phone
    Oct 03, 2009 | Proform 810 TR Treadmill
    I hear noise in my new treadmill
    where did you buy the unit. you still be under warranty. noises are funny sometimes, you think it is hear but then its over hear. There will be noise fron under the belt that is normal. sometime it is louder in a house then in a store. you may need some waxon the deck as well. culd be plastic rubbing in the belt.
    Apr 11, 2009 | FreeMotion Treadmill t7.3
    TEKK 2 treadmill motor problems
    You lower computer board is bad. are they still in business?? If not it will be time for a NEW treadmill. name brand so we can get parts
    Apr 06, 2009 | TEKK Fitness Two Treadmill
    Nordic Track NordicTrack T6.3 Treadmill Logo
    22 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
