Question about Mitsubishi WS-65857 65" Rear Projection Television
Will not power on
My Mitsubishi model nr we65857 was working great, never had any problems with it until now.  I powered it off last night and then when I came home from work this afternoon it would not power back up.  Any suggestions??
  • 123 Answers
Unplug the power cord and let is stay OFF for about 2 or 3 hours. Then power it up again and see what happens. This is what we call hard reset. It works to bring the set back to life in about 25% of occasions.
If it does not help after the hard reset above then it will need to be looked at by a tech who knows how to navigate around a protection failure. The reason it won't come back on is because the protection circuit (and electronic, intelligent fuse) has detected a severe shorted condition somewhere within the set. It is usually the main power supply, the high voltage section or one of the deflection amplifiers. But, can be from other sections within the tv. That is why you must have some diagnosis completed to find the problem.
Another cause, less frequent on this class of tv, is from bad or cold colder joints. You can check for this by just whacking the set vigorously with your hand or fist in an attempt to dislodge a cold solder joint. This may help, but don't hold your breath. If it does, look up and thank the stars in the heavens for smiling down upon you.
A turnoff as you describe is generally caused from current overload which sends the set into protection mode.
This is a very common occurrence.
FIRST: Give it a hard reset. Unplug the tv for a couple of hours, then try it again.
SECOND: Whack it good with your hand or fist. Doing so will often reactivate a bad joint, connector or cold solder.
THIRD: It may need servicing if the above two remedies bring nothing to the for.
The cause is often a failure in the power supply, high voltage or deflection amplifiers. It is never from the same cause as other sets. Cost of repair can be from $100 to $400, depending on the final diagnosis.
                      or you may try this
Well, the reset procedure would be to unplug power for a few hours and then power it back up.
Try wiggling the power cord at the end that plugs into the wall and the end that is attached to the tv. Sometimes the wire inside the molded ends goes open circuit from being crimped too hard during manufacture.
But, if still no power: Since there is no indication of power at all when you plug it in it is most likely a major power supply failure. Such repairs usually run over $100. Could be much more than that.
A set of this size and age is marginal. The rule of thumb would be if the cost of repair is more than half the cost of its replacement it may not be a wise investment.
Statistically it has been found that once a tv starts failing, even the first time, the likelyhood of another failure soon after is very high. Even for Panasonic which is generally a good model
Let me know if you have further thoughts.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 02, 2008
Mitsubishi NR-VZ800MCD Car Navigation system not working
I have exactly the same problem. The system needs to be re booted with the disc that you must have got when you bought it. It always happens when the battery is disconnected. I lost the disc and so now am looking for a copy.
Jun 17, 2013 | Computers & Internet
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Turned off cable box but did not turn off tv. storm came throuht last night green light next to reset button flashing. tv want turn off or on. tried to reset want reset. unplug tv for a while pluged in...
This model Mitsubishi has some capacitor problems with the DM board and the power supply. See my tip at which explains the problem and where to get the parts to repair your unit.
Thanks for using FixYa and for the great rating.
Apr 26, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The unit acts as though it is not receiving power. I have verified that it is receiving power, I have unplugged it as the manual directs and have waited SEVERAL minutes before replugging in and pressing...
now a days we can't sourly say that, the new electronic equipments will work for along time. you have mentioned that ur dvd player has no problem for the last 3 years. its very good.
from ur narration i think ur dvd players power supply have some problem. may it will the only problem. just try to service it. may work for the comming three years.
Dec 17, 2010 | Philips HTS3544/37 Theater System
No power - Mitsubishi 62" WD62525
you probably need to replace the lamp part #:915P020010. Hard to diagnose the exact problem without a more detail explanation on symptoms.
Sep 23, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi CS026201 TV screen problems
If the picture looked good last night
then the Tube is fine. The problem is
Power suply . I think there great tvs.
Made to last .a fair price for repair
is about 80.00-100.00
Nov 12, 2007 | Mitsubishi CS-26201 TV
TV won't turn back on
Dan27 = Recheck model # ........
lulu jr. = Slow to charge capacitor in relay / regulator power supply.......Model # , please !
Nov 06, 2007 | Televison & Video
Mitsubishi WS-65857 65" Rear Projection Television Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
