Question about Safety 1st Travel Ease Plus Play Yard Droplet PY134AIV
Stuck fold down button
Stuck button
Rear seat does not fold down when I push button. Can I manually fold down?
Give the button area a good smack! The mechanism is probably just stuck in place. Try rocking the seat back and forward while pushing it as well. It sounds simplistic, but usually does the job.
Mar 23, 2015 | 2007 Ford Explorer Eddie Bauer
2nd Row Headrest Stuck in Upright Position and will not Fold for Stow n Go
You will need to take the seat apart to determine what is not fastened to release it.
Apr 09, 2014 | 2011 Chrysler Town and Country
Stroller stuck and can't be folded
I had the same problem with mine. What I had to do was lift the Adjuster for the backrest while doing that pull the back rest all the way down ( like if baby was laying straight not at a angle) and then pull the two hand hooks and then fold down.
Mar 17, 2013 | Baby Gear
My baby stroller is not folding it stuck
Which model Safety 1st stroller do you have and which country are you in?
Feb 28, 2013 | Safety 1st Baby Gear
My stroller if not folding its stuck how can i fix that
Hi
Which model Safety 1st stroller do you have? What country are you in?
Can't open trunk using the inside lever, key or button. Any suggerstions as got perishable food stuck in there. Thanks
If your Grand Am has the split rear folding seat, you can try folding the seat down but using a wire coat hanger. Try to snake the coat hanger through the split in the seat and hook the strap to pull it to be able to fold the seat down to gain access to the trunk. http://www.gaownersclub.com/forum/attachment.php?attachmentid=17492&d=1121049659
As for the trunk being locked. Is it possible the remote lockout was activated? Try a yard stick to slide the red switch or just crawl in after you folded the seat down and removed all the food. If it's engaged, the remote solenoid will still activate (you can hear it), but the trunk won't open remotely.
Good luck and keep us posted. Thank you for using fixya
Sep 05, 2011 | 1999 Pontiac Grand Am GT
How do you get the running deck down?
If you are saying that the deck is in the folded position and will not fold down then pull the pin on the left side of the deck. If the pin is stuck then try and plug in the treadmill insert the safety key and push the down incline button on the console. This should make it so that the pin will un-jam.
Aug 21, 2010 | Proform iLog 750 Treadmill
My bugaboo frog frame will not fold down
CONTACT WWW.BUGGYPITSTOP.CO.UK THEY DO REPAIRS TO ALL BRANDS OF PUSHCHAIRS AND CAN GIVE YOU GOOD ADVISE
Jan 03, 2010 | Bugaboo Frog Stroller
Cannot release the red button to fold it up.
might sound crazy but try wd-40 on it. lemme know if it works.
Apr 24, 2009 | Peg Perego Duette MT Newport Twin Stroller
Quinny buzz wont close
I HAVE A QUINNY SPEEDI AND HAVE THE SAME PROBLEM WHATEVER YOU DO DON'T FORCE IT TO COLLAPSE AS MY DAD DID AND NOW IT WON'T LOCK EITHER THINK IT'S BROKEN INSIDE
Jun 30, 2008 | Quinny Buzz Jogger
Safety 1st Travel Ease Plus Play Yard Droplet PY134AIV Logo
101 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
