Question about Proform Exercise & Fitness
How to operate sp-100 pfpd 109
Miss placed my operating manual
Chintu-KPV
  • 202 Answers
SOURCE: BT 100 Duet telephone
hi
u may pls visit
http://www.britishtelephones.com/duet.htm
bye
Was my tip helpful?
Posted on Feb 17, 2008
ginko
  • 19396 Answers
SOURCE: i lost my operators manual!
Here is the operation manual: FinePix F480 / FinePix F485 Manual
Posted on Dec 13, 2008
jyackle5
  • 8197 Answers
SOURCE: Need operation manual
here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CER3520&siteCd=MCF
please rate if it is helpful when done. good luck
Jon
Posted on Dec 16, 2008
greenspan
  • 1734 Answers
SOURCE: SHINCO DVD - 100 English manual to operate the full function of DVD.
Go to http://chinamanuals.com - they are specialized on finding english manuals for chinese gadgets.
Posted on Feb 26, 2009
SOURCE: i have lost the operating manual for a technika
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Posted on Apr 29, 2010
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
LE MESSAGE 329
329 LD unit beam pitch adjusted incorrectly
The LD unit HP sensor does not detect
the ON condition while changing the LD
position or changing the dpi.
• After initialization of the SP modes,
SP2-109-3 or SP2-109-4 was not
executed.
• The harness is blocking the LD drive
(PCB), preventing adjustment of the
pitch.
Lazer issue.Execute above sp modes or u need to take the lazer unit out and see if anything in the way.
Nov 21, 2010 | Ricoh Aficio 1035 Copier
I need an operating manual or operating instructions for a Schiller Spirovit SP-1 spirometer. Help?
There's a service manual available http://www.welchallyn.com/documents/Non-Current%20Products/Cardiopulmonary/Schiller/SP-1%20Spirometer/Service_manual_2008_10_09_SP1.pdf from which also tells you how to operate it. It's in adobe acrobat reader format so if you don't have acrobat reader you'll need to install it first. Acrobat reader is available free from http://get.adobe.com/uk/reader/?mgiToken=2QWVV75BVSGHQ
Aug 12, 2010 | Health & Beauty
Setting the max pressure on a Craftsman compressor
The pressure setting for on off of the compressor , and the operating pressure don't have to be the same. You should have two gauges. One for tank pressure, and one for operating pressure. Turn the large knob on the operating pressure, ccw to decrease and cw (clockwise) to increase. You can download a manual for your compressor at:
http://powertool.manualsonline.com/ex/thread/view/idThread/839583
Jul 18, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Do not know how to operate the +10 key on my emerson remote contr
hello the +10 key is for channels over 100 if u have channels on your tv over 100 hit the +10 key and the last digit of the channel for example if u want channel 109 press +10 key then the 9 key hope this helps
Jun 04, 2009 | Televison & Video
How do I change Meters to Yards
Hold down the button on the side for at least 5 seconds. The "Y" will appear in the display....Now its set back to yards.
mtg
May 26, 2009 | Bushnell Tour V2 Pinseeker Laser...
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
Exercise & Fitness Logo
49 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
