Question about Jensen Car Audio & Video
Jensen A800 40w x2 MAX
What amp should I use?
Yes they information available on them they are still around. You will need a class-D 300 watt RMS amp to run them at perfect power if i remember right they are 150 watt RMS,, 450 watt max per sub.// just never mind the max it means nothing. They are a 4 ohm sub i believe so you would want to get a 1 ohm stable amp. two 4 ohm subs can be run at 1 ohm wired in series. they are actually made by audio vox corp.to wire them is easy ill give a link to do so easy to use. and handy. let me look for some info on your sub...? Yes there is info out there here is another link. Need additional help give a shout.
Rockford Fosgate Woofer WiringWizard JENSEN XS1010 Specs
Mar 07, 2016 | Jensen XS-1010 Car Subwoofer
Jensen color tv model ts2750j volume is maxed out but stll can't hear it
Check its speaker. If it is found OK, check and replace damaged component/s in the audio output circuit inside.
Oct 04, 2012 | Jensen TS2750J TV
How do you check for trouble codes on a 1994 Mitsubishi Mighty Max p/u
you have near of fuse box black plug 8 pins x2 or 7 x2 that is the plug for obd =plug for scaner engine light folow manual
Aug 08, 2012 | 1994 Mitsubishi Mighty Max
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
What is RMS @ 4 ohm x2 Channel?
root means square (RMS) is the fully audio
Apr 23, 2010 | Jensen XA92 Car Audio Amplifier
Support DX10
Nope, it is a DX9 integrated solution - not good for gameing
Integrated Nvidia® Geforce®7Series Shader model3.0 DirectX 9 graphics processor
Maximum shared memory of 256 MB
Supports RGB with max. resolution 1920 x1440 (@70Mhz*32bpp/75Mhz*16bpp)
Supports DVI-D with max. resolution 1920 x1200 (@60Mhz)
Jun 04, 2008 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen Amplifier..4 x 50WRMS at 4 Ohms
This sounds like you need a ceramic noise suppression filter/ferrule on the Power line to the amp. You should be able to get a suitable one from most car audio shops. Hope this helps, please post again if you have trouble getting one :)
Mar 28, 2007 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
