Question about Shimano Sienna Spinning Reel 4000FD
Where is the maintanence port
Is it the handle screw I Do I oil the reel thru the handle?
Change from right to left-okuma slv56
unless it is a spinning reel you can not reverse if spinning reel the screw and handle unscrew then put in opposide side of reel and retighten.
Jan 04, 2015 | Fishing
How do i remove the fishing handle on a Penn 50sw reel to replace it with a bigger handle?
from the pic I found it looks like there is maybe a small screw in the handle remove that then see if the handle unscrews from the shaft .
Oct 20, 2014 | Fishing
How to open up a okuma komodo reel
to open the reel and access the worm gear cog ( the gear that actually drives the level wind ) you will need to remove the handle, the star drag assembly, the side plate screws etc. Before you do all of that look directly at the front of the reel beneath the level wind face plate is the worm gear pawl ( the tooth that actually rides in the level wind gear itself ) there is a cap with a flat head screw driver slot in it, remove the cap ( if you can access it with the face plate on other wise youll have to go thru the steps previously mentioned) and carefully tap the reel until the pawl itself falls out there will also be a very small washer that goes inside the cap. Inspect the pawl for defects like chips on the points that ride in the gear. also inspect the worm gear it self, debris that gets lodged in the gear from regular use can chip the ends off of the pawl which will cause the pawl to stick to one side or in extreme cases stop working all together. It is possible that the worm gear cog ( located in side the reel ) is damaged but almost every reel with this issue that I have repaired (100's of them) is caused by a damaged pawl or worm gear it self Dark Side Reelz
Aug 17, 2014 | Okuma Komodo Low Profile Baitcast Reel
Left hand retrieve
Unscrew handle put on other side .
May 12, 2010 | Scientific Anglers Scientific Angler...
Change a right-handed reel to a left-handed reel(supreme s3035f)
you just have to unscrew the little screw that is on the opposite side as the reel and sometimes the reed will actually unscrew. You just unscrew it and screw it back onto the other side
Jan 25, 2010 | Shakespeare Agility Spinning Reel 6825
Start Pull cord replacement on John Deere s1400
Take the 4 bolts/screws loose that hold the shaft onto the weed-eater body, You will see the clutch drum, you need a long T20 TORX driver to loosen the screw in the center of the drum shaft. The screw probably won't come all the way out, so just pull the drum off as you loosen it.
Next you will see 3 flat clutch discs.
You may need to remove the spark plug and stuff some starter rope in the combustion chamber to keep the shaft from turning.
Unscrew these one at a time with a pair of large slip joint pliers. Be careful not to bend them and note which way they face. They unscrew clockwise I believe.
Once you have these out of the way, continue taking apart the plastic housing to gain access to the starter rope assembly. There is a spring under the rope reel, so remove the screw holding the reel in place and carefully remove the rope reel and spring.
Replace the rope, put the reel back in place and make sure the sping egages the little tab. Then wind it a few turns until there is moderate tension on the spring.
Feed the rope through the body and tie it to the T-handle. Replace the hold down screw that keeps the rope reel in place.
Test the pull tension before reassembly. It should retract the rope fully without too much tension and should not be loose. Lubricate the rope reel where it rubs against the housing with some light grade oil or lithium grease.
If everything functions, put it back together in reverse order.
Remove the rope from the combustion chamber and make sure there is no debris in it. Install the spark plug. You should be ready to go.
Aug 21, 2009 | Garden
How to remove the play, rew-ff levers and pause button to take off the front plate of a akai gx 4000 d reel to reel recorder?
Have you checked to see if there is a set screw in the handle which tightens onto the shaft? That's how most are secured. Look for a hole in the handle -- there should be a slotted screw which can be loosened with a very small scresdriver.
Apr 13, 2009 | Audio Players & Recorders
Shimano Sienna Spinning Reel 4000FD Logo
Top Shimano Fishing Experts
ray gallant
John Egan
John Egan
Andrew Taylor
Andrew Taylor
Are you a Shimano Fishing Expert? Answer questions, earn points and help others
