Question about Delta Temperature Dial Knob and Cover for 1700 Series Shower Finish: Polished Brass
Remove knob RP34358
Trying to remove outside cover, no screw.
It may be under the decorative cover, or the hot.cold emblem. Remove them with a small blade or tip of knife.
Posted on Aug 29, 2014
I cant open the drivers side door from the inside but can from the outside. I have a 2006 kia spectra
The linkage inside has come adrift. Carefully remove armrests and knobs. Remove the inside cover using wide blade screw driver. Under there is plastic sheet and holes for access. Or take it to a Kia dealership.
Nov 27, 2016 | Kia Cars & Trucks
Outside handle is loose on Schlage entry lock
Remove the inner handle and cover plate, tighten the 2 screws under the plate. Re-assemble.
Dec 21, 2013 | Schlage Hardware & Accessories
How do I remove the rear passenger break light cover to replace a bulb on an 07 Chrysler Aspen?
Remove the carpet in the back and their may be a plastic knob or two to undo ,never done one as dont see these motors here in spain but if no visable screws on the outside then its held from behind
Dec 21, 2012 | Cars & Trucks
I am trying to remove the top cover of a sunbeam CSP1 steam press to rplace the burnt out wires to the temp control .Any ideas Matt
The cover is held on by two screws underneath the top cover AND double sided stick tape, You have to remove the screws from the handle plastic knob. Also remove large knob for steam control pulling it up . Good luck domshea at aol.com
Jul 29, 2011 | Singer Electronic Steam Press Iron
The crosshairs will not up or down or side to side
Your adjustments may be internal. Sometimes what look like adjustment knobs on the outside of the scope are actually screw down covers for the adjustment screws. It helps keep the scope zeroed once set. Of course check the manual for your scope if possible but if unavailable and cannot be located online, try turning one of the "knobs" counter clock-wise to see if it might unscrew. If this happens you should find a small flat tip screwdriver adjustment screw. This will let you make the adjustments you want.
Cheers.
Apr 08, 2011 | Optics
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
How to access the timer on my kenmore 11026962502
((((top load washer machine )))
first UNPLUG THE WASHER FROM THE POWER OUTLET..!
On the headpanel looking at the knobs
you will see the side covers on the end of the head panel. depending on the model of course, the side covers pop out
lift the bottom of the cover slightly, then the top an pull to the outside
then use a philips screw driver to remove the two screws one on each side, then slightly move the headpanel towards the back , then raise it then up an you right in it
to remove the timer you will see some srews holding the timer from the back, and to remove the knob pop the time knob out an turn it clock counterwise an the knob will come off
just a comment am not sure why you chancing the timer on your washer, but iin case your washer washes an stops right at the spin cycle, and is fill w/water. is not the timer that is bad, check the lid switch may be broken!
good luck post some feedback!
Feb 01, 2010 | Kenmore Washing Machines
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Delta Temperature Dial Knob and Cover for 1700 Series Shower Finish: Polished Brass Logo
114 people viewed this question
Top Delta Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Delta Hardware and Accessory Expert? Answer questions, earn points and help others
