Question about Fujinon Stabiscope S-1640 (16x40) Binocular
Fujinon Stabiscope S1640
Compare
Dust removal inside fujinon techno-stabi binocular
The case has to be opened for this, and a can of compressed air used. There is the risk that the binocs can be knocked out of collimation, so you'd best ask a repair tech for a quote.
Sep 19, 2016 | Fujinon Techno-Stabi Binocular
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Aug 28, 2011 | Fujinon Techno-Stabi Binocular
Ranging reticle in Fujinon FMTRC-SX Binocular
Its easier to explain seeing a diagram. Go to Tascos website and download the instruction manual for the Offshore binoculars or Steiner Optic website and download the general binoculars instruction manual. It has all of Steiners models incuding those with a reticle. Most reticles are the same and there is no difference between meters and yards as your calculations are an approximate.
If your Fujinon is an ex military unit it has what is known as an M22 reticle. It is only slighlty different as it is graduated in mils but the calculations is the same. If it is the M22, google Binocular M22 manual. The military number for this is TM 9-1240-403-12 & P
Mar 22, 2009 | Fujinon Polaris FMTRC-SX (7x50) Binocular
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Fujino Stabiscope S1240d/N
I don't know about the night vision bits but if it is the same as S-1240 then the 3-pin plug is a power input.
Regards,
Tony
Feb 01, 2008 | Fujinon Stabiscope S-1240 Binocular
Stableizer not working
Baker Marine in CA will fix your Stabiscope. They told me $1500 minimum for the same problem. They are the only ones in the Western World that fix these things, truly. I know of a guy in Denmark who was told to send his to Baker. They have no competition nor any canscience!!
Aug 07, 2007 | Fuji Stabiscope (7512404)
Fujinon Stabiscope S-1640 (16x40) Binocular Logo
47 people viewed this question
Top Fuji Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Fuji Optic Expert? Answer questions, earn points and help others
