Question about ASUS KB73211 Wired USB Keyboard OEM
How do i configure Asus KB73211 English
How do configure my Asus KB73211 to English from French?
How do i change my motorola tz700 to english from french and i need instructions on how to use?
Hello Keith,
To change the language you will need to factory reset your TZ700 by following these steps: TZ700 Configuring the TZ700
For any further assistance here is the link of the user guide:
http://bit.ly/1k7rvWL
Best Regards,
Kenny
Motorola Support.
Oct 05, 2015 | Motorola Mobility TZ700 - Bluetooth...
How do i change french to english?
Do you know how to get into BIOS . that might be the only way .
Sep 16, 2015 | ASUS Computers & Internet
How to fix french dell keybnoard model SK-8115 converted into english & question mark don't work
If you are using a FRENCH keyboad on an ENGLISH configuration, take it ganted that it won't woks. You should define your keyboard as French . If you are using Windows, you should go to control Panel - Regional and Language confiuration
Press TAB Language
Press button DETAILS
Now select Language as French
Press ADD and select Language French and Keyboard French
Accept.
Select this configuration as default.
Accept and exit Control Panel
Now your French keyboard should use french language distribution
May 06, 2015 | Dell Computers & Internet
How can i turn off the green characters on my asus keyboard?
ust press the CTRL+SHIFT keys and you will switch from French to English
Aug 23, 2014 | ASUS Computers & Internet
Change french to english
when restarting ur computer before the windows display try to press the f9 or f10 key depending on your own system..you will find the system configuration there and then click on language to change to ur desired language..but if you were unable to see the english languauge option, then you have to install a new operating system to it..simply because it was installed with a french OS...
Aug 22, 2013 | Dell Vostro 1000 Notebook
I am vacationing in the USA from Switzerland. I just purchased a Nokia E71 cell phone and it is configured in English. How to change the language to French language?
the phone is region dependent.
what i mean to say is... if you have purcahse a phone within a region that has french as an alternate language you can definitely set your phone to French but if not then theres no way you can change the language to french with the phone alone.
you can check on this:
menu > settings> general > personalization> language > phone language.
Sep 01, 2010 | Nokia E71 Smartphone
I don't have English font in my Pocket PC A 620.
Not sure of French Terms, but here are the English steps:
START / SETTINGS / SYSTEM (Bottom Tab)
/ REGIONAL SETTINGS (Icon) / REGION (Bottom Tab)
Pull-down menu, select 'English'.
Jan 14, 2010 | ASUS MyPal A620 Pocket PC
ASUS KB73211 Wired USB Keyboard OEM Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
