Question about Panasonic TCP50C2 50 in. TV
Says hdmi not supported
Had hdmi hooked up then stopped working
Hdmi input not working
Try right-clicking on your desktop while tv is plugged in and select screen resolution, that should open the properties window that will allow you to activate or change resolutions for the tv or detect it. Make sure that the tv is enabled and if necessary choose to extend your desktop to it.
Jan 16, 2014 | Sylvania LC320SS9 32 in. LCD TV
Polaroid tlx-01911c hdmi with laptop says not support!
You either lost HDMI on the TV or the Laptop. The way to tell is hook up the laptop to another set aand see if it works. If it does than the problem is in the Main PCB of your TV.
Apr 10, 2012 | Polaroid TLX-01911C LCD TV
I am hooked up to At&t uverse through a DVR. It works fine except when HD light on DVR indicater comes on then TV and sound go blank. Could it be that this TV doesn't support HD?
Some DLP tvs support HD some don't.Easy to find out.Ur tv have any HDMI ports for the HDMI cables to hook up in?Yes,it support HD,no HDMI ports,than it dosen't support HD.
Oct 26, 2010 | Sony KP-53HS30 53" Rear Projection...
Hdmi port quit working, had HD sat receiver hooked to HDMI port, was working for awhile, now shows no reception?????
Need to replace the main board in your tv- it happens a lot that the hdmi stops working
Aug 19, 2009 | Televison & Video
HDMI stopped working with computer
HDMI connectors are very bad soldered inside the set,not easy to resolder for an amateur ( if you are an amateur offcourse )
Other option is the HDMI cable itself.
Jul 23, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Panasonic TCP50C2 50 in. TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
