Topfield trf 7060
Need firmware
5 digit remote code for topfield trf-7170
29560,29153,22014,22917. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 23, 2015 | Onkyo Televison & Video
Topfield trf-720 won't switch from standby to active
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 11, 2015 | Televison & Video
Our Topfield TRF 7180 records ok but pixilates and then keeps skipping when playing back. Can anyone help with is problem or do we just need to replace it? TIA
It may be a fault with the hard disk which does the recording, but I'd check the signal strength to the unit first. You need a good signal for reliable recording, one which does not drop in and out. You should use quad shield coax cable right from the aerial to the back of the Topfield
Aug 30, 2014 | Televison & Video
Howto get beter quality reproduction from a TopField TRF-2400 Set top box
Use the HDMI connection for best quality (do not upscale). If this is not possible, use the Component connection. The poorest quality comes from the Composite connecton.
Jun 06, 2014 | Televison & Video
How to scan channels on topfield pvr
See page 16
Installation > Service Search
It's advisable to do a reset first - Installation >
System Recovery > Reset Service List
Feb 17, 2014 | Televison & Video
Topfield trf-2100 manual
My TRF-2100 requests a password, I have never given the machine one.
The default 0000 does not work.
How do I reset
Apr 22, 2013 | GPS
The on-screen clock on my sony bravia kdl40w5500 lcd TV (lower RH screen) has disappeared. My problem is that I usually watch TV thru a Topfield TRF7160 PVR and I don't know whether the clock is...
http://www.topfield.co.kr/include/download.asp?dn_dir=1&fname=TRF%2D7160%5FEng%5F09Aug2010%2Epdf
Page 28...on screen display for the clock
Under Front Display make sure it isn't "disabled"
Under sub display you will find the clock and persistence option
Mar 14, 2011 | Televison & Video
I have a Yamaha RX-V667 Receiver and I need a code for the Remote Control to operate my Topfield PVR model 7160 (Australian release). Yamaha have not published any codes for any Topfield products. Do you...
just bought a Topfield trf-2460 PVR and I have got everything working except the remote control (that came with pvr) sound funtion. I can record and playback with the audio working fine but even after setting the TF remote control to work on the TV funtion, it just doesn't like it, except for the mute button, that and the off function. Any suggestions would be appreciated. Joe
Oct 24, 2010 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
