Question about Pioneer VSX-454 Receiver
Overload volume overload
Technics stereo Integrated Amplifier SU-G75 powers up few seconds then overload light appears and a clickng noise coming out of metal boxq with tag FP-3 M V RTP1P5C015 on it iis it supposed nto make c
If the receiver works at low volume, but goes into OVERLOAD and shuts down at higher volume, it means you are player the unit too long and too loud. Try yo keep the volume down to a reasonable volume.
Nov 15, 2014 | Audio Players & Recorders
Overloaded. When watching movies or dvd's or TV my receiver will shut down and it says "OVERLOADED". It happens when I have the volume at 50 or more. Am I underpowered? What do I need to do?
your probably overdriving your speakers. unit will detectand set overload when it gets hot or your speakers start to disort out. most amps is at full volume at half volume anyways
Sep 29, 2011 | JVC RX-9010V Receiver
Pioneer vsxd412 overload
OVERLOAD indicator
This lights when an analog signal is too strong (the
SIGNAL SELECT needs to be on ANALOG). It
indicates the sound is distorting and the signal
should be reduced.
Dec 28, 2009 | Pioneer VSX-D412 Receiver
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Sep 24, 2008 | Pioneer SX-205 Receiver
System is saying overload more frequently
Blow all the dust out of the unit with compressed air to prevent over heating (overload)
Aug 20, 2008 | Panasonic SA-HE200 Receiver
JVC RX6040 OVERLOAD TROUBLE
clean your volume control if that does not help take it to a tech for repairs.
Mar 29, 2007 | JVC RX-6040 Receiver
Overload
That same thing happened to me a few months back and the problem was that the terminals of a speaker were not connected properly, check all of your speaker cables, or check for a broken speaker by setting the volume of each one and make sure they all work, you might find the problem there!!!
Jan 19, 2007 | Pioneer VSX-515 Receiver
Overload
Firstly check all your speaker wiring. Any damage can cause a short which will overload the system. You might not notice it, due to the fact that when you have the system on loud, vibrations move the wires on the cabinets or elsewhere. So make certain there are no loose wires near the speakers terminals into each one. If all that is good go to the next check.
Check If the amp is getting VERY hot when the overload occurs, then it might have a faulty part(s) on it. This might have occurred if you have been using speakers that never did match the amps requirements in the first place.
Mar 12, 2017 | JVC RX-668V Receiver
21 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
