Question about GE 27GT271 TV
Picture is perfect but no sound, we use only in the summer months
I am not good with repairs, is this an easy fix or will I need to take to repair shop?
    New Friend:
  • 47 Answers
If you can't read a schematic and use a soldering iron it'll need to be taken to the repair shop.
Posted on Jun 14, 2009
Turn on ps3, within 3 seconds of boot up the power light flashes red but nothing else happens.
It is a common technical problem which can be repair with the help of PS3 Complete and Easy Repair Manual. You can now save yourself from the trouble of taking your console to some repair shop and save the money on its repairs.
You can now repair your console with PS3 complete guide within no time at home without any outside help. This is possible and very easy because of the numerous pictures and instructions available in the guide. Once you know how to fix your console, you can fix others' consoles and make money out of it :) I did that and now I am making hundreds of dollars every month. Good luck!
Jul 03, 2011 | Sony Playstation 3 (PS3) Console
My wii is 5 months old turned off after playing went to turn back on to play and have sound but no picture
This is one common error that you can fix yourself instead of sending it to the repair shop. Try Easy and Complete Guide to Wii Repair. This guide is very helpful and contains all major problems related to Wii. It also has several pictures and instructions and would help you solve any problem very easily. Apart from all, it is very cost effective and you would save hundreds of dollars on Wii Repair Manual Good luck.
Mar 28, 2011 | Nintendo Wii Console
Picture but no sound
First re-check your wire hook up and audio menu settings. If its under warranty then get it replaced if not the repair is an easy fix. Should be sameday return @ your local tv repair center.
Jun 13, 2009 | Televison & Video
We have perfect sound but only a thin horizontal line in the middle of the screen.
this is a capacitor that has gone bad in the vertical delfection stage of the tv. it is an very easy and cheap fix if you know someone who knows how to solder and replace electronic components. If not then you'll just have to get another tv as taking it into a tv repair shop is not worth the cost. You could get another tv for what they will charge you to repair it,
May 31, 2009 | Sanyo AVM-3659S 36" TV
MODEL HLC 22 R TV/DVD COMBO
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.Switch input mode Vitally
Mar 26, 2009 | Haier HLC19R 19 in. LCD TV/DVD Combo
Perfect sound, no picture - RCA F32649
if you know how to solder ,re solder your tv, but before doing that replace or used other RCA cord
Aug 09, 2008 | RCA F32649 32" TV
Warped picture
Good Day, jamelpp;
Sounds like the warped picture may be caused by the convergence output IC's, but try this first:
E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
Good Luck, big IRISH.
May 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Black screen and no sound
I realized that there is a 90 day warrantee on parts and a 30 day limited warrantee on labor for the  repairs that were done. As I stated, the original problem was the picture shrinking after a few minutes of the set being on. The repair firm took my control board with them. When they came back to install the repaired control board in my set there was a load spark during the installation, after which I had a black screen and no sound.  The repair firm took my set them and installed a "CAP Kit", a STRM6511, and a "D1881". The set worked perfectly until two days ago.
I called the repair firm an they are coming out this Thursday to check out my TV.   I am hoping the problem is related to the failure of one of the parts installed to fix a similar problem which occurred after the sparking incident.
Mar 31, 2008 | Mitsubishi CS-40505 TV
Taking pictures
First look on the back and with the camera on press the DISP or DISPLAY button. If you still have a problem after doing this, then it needs to be repaired. You mention the camera is only 4 months old, and is thus still under warranty. Call 1-800-828-4040 or 1-800-OK-CANON (1-800-652-2666) to have it repaired for free under its warranty. And here's its warranty:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=224&modelid=14919
Feb 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
GE 27GT271 TV Logo
75 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
