Question about Sunbeam Holmes Room Heater One Touch Digital Controls, Hfh442-Um
What does a beeping noise mean from the space heater
My space heater is beeping. What does that mean.
Has no video display. Beep codes are all same length, interval between beeps vary. Beep-long space-beep-short space-beep-short space-beep-long space-beep.
it's likely a problem with your motherboard and specifically your video card component on it.. you could add a new video board in one of the expansion slots as a workaround, although if the motherboard is completely gone what you will need to do to solve the issue is to have it serviced or replaced. It might cost half what you paid for your computer if it's a relatively new computer or might not be worth the repair if it's an old computer.
If you post the computer make and model we can help you find the beep codes for more specifics, that's the real way to find out what the beep codes mean in your specific case.
Sep 16, 2015 | Computers & Internet
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
Product Name : Intel Motherboard Dg31gl Type : Mother Board Problem : 3 beeps continously then space then sham four then space again space again its repeating d same give me any solution
Replace the processor. The 3 beeps means its the processor at fault..
continuous beeps with space in between means its the rams.. No beeps at all means its the clock speed.
from what your saying it sounds like the processor.
Dec 28, 2012 | Computers & Internet
2004 Nissan Titan-When I change my Heater to A/C or vice versa I
There is an actuator that moves the diverter that makes the noise.
See this thread for a how-to fix.
http://www.titantalk.com/forums/titan-problems-dealer-service/105851-how-fix-annoying-clicking-heater-ac-actuator-under-dash-w-pics.html
As for the beeping noise, could be the tire pressure sensor. When it beeps, look for a yellow warning light that looks like this ( ! ) Means you have a tire that is low on air.
Apr 12, 2010 | 2004 Nissan Titan
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
Water heater is beeping with er- 120 flashing
if water heater is beeping E-2 it means that the water heater has gotten to high above water heater set point. Things to check
- there hot water being feed from boiler still
- is zone valve or pump isolated stopping flow of water to water heater
-check sensor readings
Jan 01, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Sunbeam Holmes Room Heater One Touch Digital Controls, Hfh442-Um Logo
91 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
