Question about Sears Tools & Hardware - Others
Remove brushes from sears buffer
How to remove brushes for cleaning
Makita buffer clicking, sparking and burn smell, power loss upon immediate use
it is a armature problem common to makita products
replacing one armature with a new one does not solve the problem as the fault is a design fault
probably armature not wired heavy enough for continuous running
consider replacing it with a better brand that enables continuous operation
Nov 24, 2016 | Makita Vacuums
How do replace belt on dc41
Ouch The video below shows how to to remove the brush head and how to clean it. I almost think that Dyson didn't ever expect this belt to break. The rest of the disassembly to get to the brush seems to be done by removing torx screws, I have not been able to find a replacement from dyson. A google search shows several sites that sell a replacement belt.
Dyson DC41 DC43 Resetting the brush bar Official Dyson video
Link to sears parts direct has a diagram of the brush head.
DYSON INC Vacuum Parts Model DC41 2013
Link to Dyson Parts with phone number for customer care.
Variant Parts
Sep 23, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
Buffer doe not turn on
Bad Carbon brushes. Look here on how to replace http://www.detailedimage.com/Ask-a-Pro/flex-3401-vrg-brush-replacement/
Apr 09, 2014 | Flex Buffer XC 3401 VRG
Makita 9227c polisher started clicking and i smell smoke
sounds like you have a problem with the armature. To easily check UNPLUG tool and turn the spindle by hand and listen for the clicking. It sounds like it may be a raised commutator bar. You can also remove the brushes and look into the brush tube with a flashlight and look for a major discoloration of the bars or one that is raised.
Dec 18, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
I have a Sears electronic typewritter and it needs a new 'daisy wheel' or how can I clean this one?
Most sears were made by SCM if so those P/W's are available. You can clean it by removing it and brushing the letters with a stiff tooth brush or soaking it in mineral spirits.
DickyO
Aug 24, 2011 | Office Equipment & Supplies
Hi ! My unit do not turn to its right rpm, erratic power.
could be a couple things. UNPLUG tool and remove one handle half and see if it is jammed up with lambswool from the bonnet. It can get under the brushes causing the erratic power. If thoroughly clean the entire motor housing and then remove and check the brushes for wear. Let me know if you need more assistance.
May 26, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
If this is another thing where I have to pay to get info then I'll just say thanks anyhow. I'm 61 years old and just unemployed so I can't honestly afford to pay you. If you trust in human nature I'll do...
Hello rwstv,
Thick line appear on screen because of devective buffer pcb, open and clean the conector may solve that problem. But it's not only from buffer pcb, panel itself can cause line.
My suggestions is, clean the buffer pcb conector with brush, if still not working, you may try to replace buffer PCB. But it still not work, panel must be changed.
Good Luck.
Apr 19, 2011 | Samsung 50 in. Plasma TV
I have two sanders that have both conked out on me. It started shorting out, and then they both just eventually died. I have had this problem before and had to get it fixed. I'm in a rush and would like...
could be lambs wool under the brushes. If you are comfortable with disassembly unplug tool and remove the brush caps, check for continuity from the cord to the brush holders. If none then you have to move backwards, then you have a problem possibly with stuck brushes and the tool would need completely cleaned. Let me know if you need more asistance
Jul 26, 2010 | Milwaukee Tool 7" /9" Heavy - Duty...
The agitator on my upright 116.35923500 does not turn unless it is in an almost laying down position
116 generally indicates you are using a KENMORE???? If so this is a SEARS catalogue number for their cross reference , not a model number....
So assuming that I will take a stab here The problem you describe is generally caused by a slipping belt, in an upright vac or power head. When you lower the handle the weight is relieved from the head of an the vac and so the brush will turn more freely. Take your model # to SEARS and pick up 2 fresh belts, one for now and one for future.
< Remove the lower cover,looking for screws on the underside and pull the brush roll out. Clean the hair and **** out of the ends of the brush under its bearing caps, while watching for spacer washers. Spray WD40 on the brush shaft and wipe away excess with a rag.Then reinstall the new belt in reverse order. Pay special attention the how the lower panel is inserted when removing to change the belt. Quite often these housings have a lip which seats into the bumper area of a vac. Please post back with more info
Oct 31, 2009 | Vacuums
Tools & Hardware - Others Logo
15 people viewed this question
Top Sears Tools & Hardware - Others Experts
Are you a Sears Tool and Hardware - Other Expert? Answer questions, earn points and help others
