Question about Sentry 880CD Headphones
Ear cup deteriorate
Are there replacement ear covers?
I need help to fix my headphones
In most cases the wires are small and you have to replace the whole cord that goes from the jack to the headphone. If you take the ear cup pad off, look for screws to remove the cover over the speaker. If there are no screws then it is a press on or a sealed ear cup. You will ruin it trying to get it apart. If you do get it apart, you should see where the cable comes in the earcup and fastens to the speaker and the to the other cable that goes to the other ear cup. You will need to use a soldering iron to change the cables. Pay attention to the colors of the wires and where they connect or you will have a phase issue.
Jun 27, 2014 | Audio Players & Recorders
Soul by ludacris left ear cup problem
BEst to just try to find a repair shop for that sort of thing. Disecting headphones is a risky venture, and 9/10 it results in a frustrated, headphoneless user.
Jan 30, 2014 | SOUL by Ludacris Bolt Signature Series...
Ear pads falling apart
Please follow the proper instructions below
Ear cushion reattachment
If the ear cushions come off your headphones,
reattach them as follows:
1. Fit the mounting flange inside the rim of the ear cup.
2. Make sure it attaches smoothly and uniformly within the entire ear cup. (Do not remove the ear cup lining material).
Ear cushions may need to be replaced due to normal wear and tear. To order replacement ear cushions, call 1-888-865-2700.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Bose 41213 Headphones
Hello, I just got a Bose QC3 on eBay. It works fine except the cable which is not the original one but a one from T'nB and the left earpiece has a very annoying whistling noise when I press it or even...
i would buy a new ear cup.and a new battery. and perhaps a new cord.
i had a problem w/ my ear cups and i noticed that when i bought the new ear cups the sound was better.
i also read that if the battery got alot of usage (4 plus year) then the whistling noise comes from that. i'm starting to have the same problem. i have had my headphones for a long time. i think like anything else that operates on batteries its time to change it.
Mar 06, 2011 | Bose QuietComfort 3 Acoustic Noise...
How much zoom would be sufficint 4 a super picture?
Sound travels through different kinds of matter. Sound travels through gases,
liquids and solids. 1. Hold a plastic bag of water against one of your ears. Cover
your other ear with your hand. Have someone hold a ticking
clock against the bag of water. Listen.
2. Keep the clock in the same place. Remove the bag of water. Listen.
3. Place a block of wood between your ear and the clock. Listen.
Do you hear the clock best through the air, the water or the wood?
B. 1. Place the clock 20 cm away from your ear and listen to the ticking.
2. Have your partner hold the clock at the 20-cm mark on the meter
stick. Place your ear at the end of the meter stick and listen.
3. Have your partner hold a metal rod to your ear and place the clock
against the rod 20 cm away from your ear. Listen. Does sound move
differently through some solids than it does through others?
C. 1. Take the plastic cups (telephone) and hold your cup to your ear
while your friend talks slowly and clearly into the other cup. Keep
the string tight. How does it work? What is vibrating? How do the
vibrations of your friend's voice reach your ear?
2. Can a third person talk and listen if another cup with a string is
attached? Take the separate cup with the string and attach it to
the first line. Keep all strings tight while one friend talks into
one cup and the other two friends listen. Can you hear the message
of the third party? How many lines could you attach? Does each
addition weaken the vibrations?
Jan 04, 2011 | Answer Racing Ion Motorcycle Jersey 2010
Opening bose on-ear headphone speaker's cup
Apparently there are screws hidden in the small foam ring covering the plastic (not the earcushion). Try it removing the foam and tell me how it goes!
May 02, 2010 | Bose in-ear headphones - Black with...
I have a Recoton Advent wireless headset with full over-the ear coverings. Model unknown - probably AW 770 or Aw720. The headphone coverings are deteriorating and continue to crumble. I would like to...
Write the mfr. I have same issue and made a replacement by slicing polyurethane foam to fit and gluing it with Barge cement. Pretty effective. Other options are cutting felt or fleece. I doubt replacements are easily found.
Mar 07, 2018 | Recoton Advent Radio Communications
Do you refurbish your head sets. The rubber ear protectors & the rubber in the head bar has deteriorated. Thanks Stan Jackson
You should be able to easily obtain replacement ear protectors from the manufacturer and also replacement headband covers.
Oct 05, 2009 | Radio Communications
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
A Bose headset is buzzing
The speaker in that Ear Cup may be blown. You should consider replacing the set with a newer one.
If you listen to this with that static noise you risk serious injury to your ear.
Jan 04, 2009 | Radio Communications
Sentry 880CD Headphones Logo
29 people viewed this question
Top Sentry Audio Players & Recorders Experts
 Grubhead
Grubhead
Tom Chichester
Are you a Sentry Audio Player and Recorder Expert? Answer questions, earn points and help others
