Question about Throttle Position Sensor Ford Bronco 96 95 94 93 92 91 90 89 Ss10426
How to install tps on 1982 ford f150 xl
Wont idel
    Sergeant:
  • 462 Answers
Mounted to side of throttle body disconnect battery unbolt old usually just 2 or 3 screws
Posted on Sep 07, 2014
Its a Ford F150 1982 model and my reverse lights wont come on, my turn signals are also not working. I replaced the fuses and bulbs but it didnt fix anything. What do I do?
these bulbs will insert into the socket both ways. Only one way is correct. If it glows dimly, turn that bulb around. If they dont work at all, you have a bad ground.
Feb 27, 2011 | 1982 Ford F 150
1988 ford f150 5.0ltr runs but wont idel
did yo check the iac and the tps?
Jan 19, 2011 | 1988 Ford F 150
I have a 1982 ford f150. trans problems
transmission is stuck in between gears, clutch is broken or rear end is locked up
Jun 16, 2010 | 1982 Ford F 150
Some times my 1984 ford f150 idels fine when its in park(some times)but when i put it in drive or reverse idel drops about 500 or so rpm sputters for a little bit and then dies. Some times it runs fine...
In general, yes. This is a carb tuning issue. Another possibility is a vacuum leak somewhere, but most likely, it's a carb issue. You'll typically see your rpm drop a bit when you put it in gear, but that it sometimes stalls out points to a carb issue.
May 20, 2010 | 1984 Ford F 150
Fuse panel diagramm 1982 ford f150
my email is flynow_1@hotmail.com. I have the picture but it wont upload onto this. Send me your email and I'll send it to you. Thanks
Oct 21, 2009 | 1982 Ford F 150
Stalls when you let clutch out not opperator error, erratic idel have changed tps,egr sensior,idel air controll sensior,no vaccume leaks, good power once rolling,will surge on highway,replaced fuel filter.
How about replacing plugs, wires, distributor cap. one way i check to see if my wires are bad is to turn on the car/truck at night(no lights) and check the wires to see if they're arching to the engine block. if they are, time to replace. other than that try replacing intake manifold gasket.
Sep 24, 2009 | 1995 Ford F150 Styleside Regular Cab
1997 ford 150 will not idel
It could be a idelpositioning sensor, or throttle body sensor.
Mar 06, 2009 | 1997 Ford F150 Regular Cab
1982 ford f1504x4 truck
sounds like you need a heavier duty starter. Talk to a starter re builder and tell him the problem and he will probably come up with a heavier starter that will do the job.
Jul 03, 2008 | 1982 Ford F 150
Throttle Position Sensor Ford Bronco 96 95 94 93 92 91 90 89 Ss10426 Logo
96 people viewed this question
Top Delphi Vehicle Parts & Accessories Experts
Tom Chichester
Richard Warren
Richard Warren
Are you a Delphi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
