Question about Jenn-Air Washing Machines
Jenn-air electric griddle model a302
I need replacement knobs
SOURCE: Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Posted on Aug 12, 2008
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
SOURCE: I'm looking for replacement knobs for my Jenn Air
I agree...the knobs are a POS.......redesign needs to happen....
Posted on Nov 27, 2009
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
I NEED PRICE AND AVAILABILITY ON JENN AIR MODEL NO. 140 FOR THE FOLLOWING PARTS: UPPER HEATING UNIT OF OVEN, OVEN SELECTION KNOB, OVEN THERMOSTAT KNOB AND THREE SMALL KNOBS THAT ASSIST IS SETTING TIME,...
I suggest you contact your local Jenn-Air dealer for prices. Alternatively, up could contact any of the FixYa.com advertisers which will appear on the page with this answer. FixYa.com is not a parts supply web site.
Thanks for visiting today.
Jan 07, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a jenn air model jer8850aaw replaced the bottom element and now the element will not shut off what could be the problem?
If the element wont shut off sounds like the oven thermostat control made be faulty, if its a manual knob you use to turn the oven on you'll need to replace it, but if its electronically controlled you'll need to replace what the call the erc or clock.
Oct 31, 2010 | Jenn-Air JER8850 Electric Kitchen Range
The male plug on the griddle is broken.
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Apr 23, 2010 | Jenn-Air JED8230 Electric Cooktop
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
Jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Sep 16, 2008 | Grilling
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Washing Machines Logo
Top Jenn-Air Washing Machines Experts
Are you a Jenn-Air Washing Machine Expert? Answer questions, earn points and help others
