Question about Bosch Dishwashers
Bosh shx2arl5uc will not drain
Will not drain
How I get to the drain pump to check if blocked on Bosh Logixx Variodrawer dishwasher please.
Pull the inlet hose off the drain pump to check for clogs. If this goes into a garbage disposal back flush the pump with a pressurized water source will also work. This means removing the unit from the house of course. Do you hear the drain pump running after a cycle completes?
Jan 27, 2017 | Dishwashers
I just bought a Bosh Ecosense dishwasher. I need to know size of the water supply line and drain hose?
The size of the water supply line is 3/8th inch (10mm)
The drain line is 7/8th inch (22mm)
Oct 10, 2011 | Bosch Dishwashers
My bosh frontload washer wont spin or drain
If it does not drain, then it will not spin.
Locate and clean pump filter.
Aug 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher growling and not draining
Bosh dishwashers work off a gravity pump system. They sometimes require a stronger pump. Make sure if it has a air gap either at the top of the sink or johnston T or in the wall that, that is not plugged. They are very sensitive to how the drainelines are set as well. If it was installed prfessionally, call the installer back out as they should warranty there install for 1 year. Also all products have a 1 year MF warranty as well. You should be able to get a BOSH tech out at NO charge to see if it is a deffective pump.
May 04, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Dishwasher won't drain -it's only 3 months old
Yes they do have a drainage problem! I worked for a Sear install team. You need to have the installer come back out, if they did the install correctly and you still have problems then sears needs to send a service tech out. If they can't fix it or tell you it is a install error then be persistent and tell them you want a BOSH TECH out. You more than likely need a stronger pump as Bosh DW work off a gravity type pump system. Keep in mind Sears installers guarantee there install for 1 year and all products come with a 1yr MF warranty. If you purchased a warranty or PA agreement the you will be entitled to a new unit if that one is not fixable. If you have a garbage disposer, they work best when routed into one.
Jan 17, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
18 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
