Question about Mitsubishi WD-57732 Projection Television
Wont stay on
Will run for 5 seconds then shuts off
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
My 95 tahoe starts but dont stay on. Fuel wont stay pumping from tbi. Just swapped a motor from 80's camaro. Was running real good in box chevy perfect. Now fuel wont stay flowing out of injectors. Already...
did you install the oil pressure switch origional to the tahoe? The tahoe uses a low oil pressure shutdown, instead of an inertia switch to shut off the fuel pump in the event of an accident. If the pressure circuit does not close within 3 seconds after the engine starts the fuel pump shuts off. This is in case the truck is on its side or upside down the pump will shut off.
Aug 19, 2010 | 1995 Chevrolet Tahoe
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
91 4x4 starts wont sta running more than a few seconds
maybe your mass air flow sensor on your airbox?
May 05, 2009 | 1990 Toyota Pickup
I have a 95 Maxima I changed the fuel injectors and now the car wont start.  so i put the old injectors back and it still wont turn over,  It stay on for about 2 sec can anyone help me
I assume you bled off fuel pressure before you installed the injectors. Try this to pressurize the fuel system. Turn the key to "on" position and wait 5 seconds. AT same time, listen carefully for a buzz sound that means the fuel pump is running to pressurize the system. It will shut off after 5 seconds. Then, turn off the key and wait 30 seconds for the computer power relay to shut off. Then, turn the key to "on" again. Thsi will run the fuel pump for another 5 seconds. Repeat 5 times. Fuel system should be pressurized now.
If it doesn't start now, you may have done something while you were changing the injector. good luck
Jan 09, 2009 | 1987 Ford Tempo
2000 jeep gc wont stay running
Lock all the doors unlock the doors with the key because the security system thinks its being stolen and it shuts off the injectors
Try another key the chip in yours may be defective.
www.aceautomotive1.com
Aug 16, 2008 | 2000 Jeep Grand Cherokee
Mitsubishi WD-57732 Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
