Question about RCA RP-3765 Clock Radio
Had a power outage, now the cd won't play - RCA RP-3765 Clock Radio
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Dell inspiron 560 won't recognize network adapter
Try reinstalling the NIC driver. If its separate network card, connected in PCI adapter, try to remove and plug it back in to see if its found after.
If these actions do not help, maybe NIC was damager with the power outage, it can happen.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
if there is no netework adapter in device manager or any device that is not instaled try checking in BIOS if it is enabled. sometimes after power loss bios is reset. if it is enabled in BIOS that short power outage probably killed your network adapter. you can add some PCI network adapter and solve your problem.
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
Air conditioner won't come on after power outage
i would suggest looking for a hidden reset button on the unit or check any fuses/trips connected with it.
May 30, 2012 | Heating & Cooling
Hello!WE had recent power outage ,now door opener won't work.unit has power lights come on when remote pad pressed,but nodoor action?thank you
Along with the power outage you probably also had a power surge. You need to pull the logic board and check the printed circuit board for burnt or missing traces. Unplug the unit first.
Sep 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Philips display went out when power outage occurred
I can supply a replacement display from a scrapped unit, I'm in the UK, search on ebay for seller fluffcat1 and contact me.
Oct 04, 2007 | Philips CDR775 2-Disc CD Recorder
CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Jun 04, 2007 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
RCA RP-3765 Clock Radio Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
