Question about Ruud Matching Split Air Conditioner
Where is the reset button located on the outside unit and is there a reset button on the inside unit?
  • 1 more comment
  • kdhottmama15 Jun 14, 2009
    I did that all ready and it won't start. What happend was the transformer got hit by lightning and wen the power came bak on there was no air and it will not start the thermostat clicks but nothing in the attic starts on the inside unit and the outside unit won'tstart either. Any idea on where the reset button on either unit is?
  • 867 Answers
Try turning the circuit breaker on and off at your power box, it may work
Posted on Jun 14, 2009
My lg split system model is LMS304V-4. the fan inside turns on for 3 minutes then turns off but the compressor does not cut in at all. the green light on the left of the panel inside blinks 5 times stops...
I could not find the model number listed in your inquiry, but a lot of LG minispits use the 5 blinking light for indication of poor communication between inside and outside units. Try this before replacing control boards. Power down the outside unit. Remove the cover for the control wiring and loosen and retighten the 4 wire going into the inside unit. Then go in and remove the shroud cover for the inside unit and find the other end of the control wires and loosen and retighten them. Sometimes over time corrosion builds up and causes loss of signal and the lack of proper signal during communication is similar to someone talking to you while you are listening to loud music while wearing a headset. You cannot hear what is being said because to much noise. Remove the cover on the outside unit and see if it has a white reset button. If it does have a reset button after you have performed steps above, try restoring power and pressing the reset button. If it does not have a reset button, it should automatically reset when power is turned back on. If these steps do not help you will probably have to replace the control board on the condensing unit.
Hope this helps.
Dec 10, 2014 | LG Heating & Cooling
Where is reset button on my outside a/c unit
If you are talking about the condensor that sits outside,there are high pressure and low pressure devices that have a red button on the top of them, turn off power and push the button. They are sometines located inside the unit under the fan. Generally there are none and the unit has internal overloads that kick it out. they reset themselves after the compressor cools down. If it resets after cooling down then ask yourself why it got hot. use a hose and clean the coils around the unit.sometimes helps. make sure fan is running on the condensor outside. It should come on first.
Aug 13, 2014 | Heating & Cooling
My outside A/C unit is not coming on
might be it is relay problem in pcb. Pls check the cord then relay by a technician,
Oct 14, 2013 | Goodman Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
I have Goodman A/C Unit which was working yesterday morning but the outside unit will not come one. I was told to locate the reset button but unable to locate the button.
This could actually be a capacitor issue and pressing the reset button wouldn't do much good. Go to the back of your outside unit and look inside the access panel with the electrical warning sticker on it; if the capacitor is bowed up at the top, it needs to be replaced. If it turns out to be the capacitor, follow this link for a new capacitor replacement kit, it will save you hundreds of more dollars than calling an HVAC repair company to charge you an arm and a leg. The kit also comes with the proper tools and parts needed as well as detailed instructions on how to replace the part yourself. http://hvacrepairkits.com/index.php/content/article/68
I hope this helps!
Aug 17, 2011 | Goodman CKL36AR36 Air Conditioner
Outside fan not turning on.
Reset buttons (if applicable) are usually located near the brass service valves.
There is a circuit breaker in your electrical panel that furnishes voltage to your outdoor unit. This is a seperate circuit from the indoor unit.
Outdoor units should have a service disconnect mounted within 10-15 feet. This service disconnect may have fuses or a circuit breaker in it.
Usually if a fuse opens, you will not be able to tell from a visual inspection. It is best to take the fuse to your local hardware store where they can test it and offer a replacement if needed.
I hope you find this to be very helpful moving forward.
Apr 21, 2010 | Heating & Cooling
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Our dog chewed on some of the wires, which I've reattached before and had the thing work. This time they won't reconnect, though the unit itself can be run by pushing a button in the unit.
if this is a central unit and the button you refer to is on the outside condensing unit, the wiring is propbably not the issue, the manual reset button is generally a high pressure safety switch, when you reset it if it runs for a few minutes then shuts off again unit you can reset it, you probably need to wash your outdoor coil. (it may look clean from the outside and still be blocked from the inside) shut off the power, verify that power is off, remoave the top of the unit and wash with a hose from the inside of the coil to the outside, make sure you clean all ares of the coil, use the hose pressure to "push' any debris through the coil then rinse the outside, reassemble, let dry completely and then start the system
Jul 19, 2009 | Heating & Cooling
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Lg ductless no ac
I may not be of much help but I may be able to guide you into some diagnosos. If there is a communication problem between the inside and outside unit, both on the inside and outside units a colored LED will bling 5 times then pause for 3 seconds. The 33 and 44 codes are confusing to me because I have never seen this. Try resetting the outside unit with no call for heat or cool from the inside unit. After about 20 seconds, restore power to the outside unit. Go in and turn on the remote and make sure you lower the cool setting more than degrees cooler than the room temp. After 3 minutes the outside unit should turn on. If you get an error code of either 1, 2 or 5 blinks document it for the technician. If you continue to get your 33 and 44, you have a bad control board. If all else fails, press and hold the button located on the lower left side of the art unit and hold for about 5 seconds. If it still no longer works, now you will need the help of someone who knows these units.
Sep 08, 2007 | LG Art Cool LA121CNP wall/window Air...
Ruud Matching Split Air Conditioner Logo
266 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
