Question about Schwinn Exercise & Fitness
Schwinn x r 10
Strap set up
What year was this bike made Schwinn Continental 10 speed serial# JK562864
Look for an alphanumeric on the head tube or head badge (where the fork goes through frame) and then Google "Schwinn date codes". It might be worth $200 or more if in prime condition and pre-70's, or much less.
May 16, 2016 | Schwinn Cycling
Date of manufacture of predator serial number 00583 schwinn
That is better, now we have something to go on :>)
http://re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Lots of info
  • Schwinn Serial Numbers and Date Codes - Re-Cycle re-cycle.com/History/Schwinn/SwnB_Serial.aspx Schwinn Serial number and date code ... Schwinn Serial Numbers and Date ... out the crankset to check for a date code. If you have a Schwinn from ...
  • Schwinn Serial Number Info - BMXmuseum.com Forums bmxmuseum.com/forums/viewtopic.php?id=18201
    • LAST UPDATED: 2013-05-10
    • 51 POSTS
    • FIRST POST: 2007-06-28
    Schwinn serial number sequences, ... separate date code number on the right rear fork end that ... I have a 1980 schwinn predator.
  • Schwinn serial number date codes - Angelfire www.angelfire.com/rant/allday101/SchwinnCodes1.html this chart applies to chicago schwinn`s only. scroll down for the date codes links ... if the serial numbers are found on the left rear dropout
  • Determine the Manufacturing Date waterfordbikes.com/w/culture/paramount/paramount-dating Determine the Manufacturing Date. ... Schwinn would add another digit, ... serial number 018524. All Paramount tandem production had ceased by the end of 1979.
  • Schwinn Lightweight Data Book (Serial Numbers) schwinnbikeforum.com/SLDB/serial.htm Serial Numbers Chicago built Schwinn Serial Numbers for the ... a letter representing the month of manufacture, a number indicating the last ... Schwinn Date Codes ...
  • Schwinn serial number lookup tool schwinncruisers.com/serial-number.html Vintage Schwinn serial number lookup. Enter your Schwinn serial number in the box and click "find" to see what date and year your Schwinn ... Schwinn serial numbers ...
  • Bike serial numbers https://bikeindex.org/serials Serial numbers All bikes 1 all have unique serial numbers. Most bicycles have their serial number engraved beneath their bottom bracket, but sometimes serial numbers ...
  • How to Date Schwinn Bicycles ' eHow www.ehow.com > Hobbies, Games & Toys > Hobbies > Antiquing How to Date Schwinn Bicycles. The Schwinn Bicycle Co. is an American bicycle company and a ... For Schwinn's the serial number location has moved to ...
  • Nov 10, 2015 | Schwinn Cycling
    Adjust handlebar height on Schwinn Varsity
    I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
    Jun 25, 2012 | Schwinn Cycling
    Schwinn seat bag....how to install A picture of correct installation would be helpful as straps don't seem to go anywhere
    The bags are slightly different but the pictures should give you the idea.
    http://www.cambridgebicycle.com/design/accessories.htm
    http://triathlons.thefuntimesguide.com/2009/03/cycling_gear.php with a blowup.
    The straps loop over the seat rails then rejoin under the bag; the front loops go around the seatpost.
    Search engines find everything.
    Jun 19, 2011 | Schwinn Bicycle Seat Bag Black Bike Under...
    Determining pedal size for 26 inch schwinn mirada bicycle and compatable upgrade pedals
    This write-up explains it in detail.
    http://www.sheldonbrown.com/gloss_p.html#pedal
    Search the page for "Thread sizes".
    As far as upgrade pedals go, that would depend on the rider's preferences (toe straps, clipless) and comfort level with them. A Bike Shop will probably stock and install anything you could want.
    Keep in mind that the left side is left threaded.
    Dec 26, 2010 | Schwinn Cycling
    Load indicator and odometer and spedometer just quit working. Bike is ancient-circa 1988-but otherwise works well.
    Same here. Can't find the part online. Local Schwinn dealer said they haven't made that part in at least 10 years. I put on a regular bicycle Cateye odometer. At least I have a measure, although it does feel like it agrees with the Schwinn odometer, even when I set the wheel size to just 100 cm I think it is still ~20% high.
    Nov 15, 2010 | Schwinn Original Airdyne
    Just installed the schwinn hitch rack 3 on the hitch of our vehicle. How to we fasten bicycles on rack? men'a AND women's bikes.
    For the ladies model you need an adapter bar to make it like a mans model. , mens, you just set arms on the bike's top bar and bungee it or if it has straps use them. Make sure that your pedals do not scratch your trunk by either buying foam pedal blocks or wrap and tape them. Put the womans bike on first.
    Oct 02, 2010 | Schwinn Cycling
    I have this Schwinn Trailblazer Bike Trailer and Stroller. It is wonderful. However there is a strap that is bolted on to the main frame and to the spring end that connects to the bike hitch. My husband is...
    This particular strap is a safety backup strap. This strap is just for in case that the first one securing the trailer to the bike breaks so it will still stay connected to your bike.
    May 20, 2010 | Schwinn Trailblazer Bike Trailer
    Have a Schwinn xr7 exerciser bike, need new pedals or straps
    I am not sure what type of bike you have (did not bother looking it up), but I myself too have a schwinn exercise bike (recumbent) and the straps recently broke, and when I sent customer service an email from their site they said they sell replacement straps.
    I included the kind of bike I had when I inquired so the price given to me might be exclusive to my bike only, so you'll have to contact customer support yourself to see if they sell replacement straps for your bike and if so how much.
    Mar 15, 2009 | Cycling
    Exercise & Fitness Logo
    32 people viewed this question
    Top Schwinn Exercise & Fitness Experts
    David Payne
    David Payne
    Matt Olenzek
    Matt Olenzek
    Bill Boyd
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
