Question about Dell E2210 22" Widescreen Flat Panel Monitor
Backlight faint The backlight is faint
Has sound ,no backlight, faint image
If you see a faint image, backlight is there, but its intensity is less. There are many reasons for this fault. From back-light inverter board to LCD panel should be checked for the fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Toshiba 50L1350U 50" Class 1080p LED TV
Powers on, no display
Do you have sound? If so, dim the lights in the room and shine a bright flashlight on the screen and see if you have a faint picture. If you have a faint picture, you have a backlight problem. On most of those sets, the backlight inverter is combined with the power supply so that power supply/inverter board will more than likely be the culprit!
Dec 07, 2013 | Vizio E420VA 42 in. LCD HDTV
How to fix the backlight
wow, iv seen that before, to us it means your panel is out.
sorry, if i am not mistaken, the backlight is built into the panel.
Sep 08, 2012 | Vizio E320VP 32" LCD TV
I have a gateway FPD2185W TFT Monitor with the power button always ON (blue) and no video. Nothing is working: menu, input, etc..
Look at the monitor at and angle from the top, bottom or side. You are looking for a faint picture of what you would usually see. You will need some good light to see this. If you do see a faint picture this means the backlight on the lcd is broken. I would get a new monitor, I would not recommend trying to replace the backlight.
Apr 05, 2011 | Gateway Computers & Internet
Hello, My Samsung monitor(Model 740N) blanked out suddenly. I tried to restart and nothing appeared on the screen. I am not able to go in the safe mode too as nothing is visible. While the system...
If you can see the screen image very faintly, the backlight system has shut down. This can be due to a component failure (driver transistor, transformer, or ccfl tube) or action by the backlight controller. Without disassembly and more information (test results) from within it is not possible to diagnose further.
Apr 24, 2010 | Samsung SyncMaster 720N Monitor
Beoken backlight
u kant
u will have to get another screen 4 ur psp
Nov 18, 2008 | Sony ACY-BR81/OB
No/very faint picture on screen
mslynn, you have either a bad backlight or backlight inverter board that changes DC to AC to light the backlight.
When the unit is taken apart you will be able to tell.
Feb 19, 2008 | Toshiba Satellite 1415-S173 Notebook
Faint picture on screen
Most likely the backlight on your LCD has gone out. See http://www.inventgeek.com/Projects/BacklightFix/Overview.aspx for a guide on replacing the backlight.
Nov 10, 2007 | IBM ThinkPad T22 2647 Notebook
Dell Latitude LCD screen is dark, but computer is still working.
It sounds like the backlight has burned out. The faint light you are seeing is ambient light in your room being reflected through the LCD. Try it in a perfectly dark room and see if you can see anything on the screen. The following page should give you a sense of what is involved in replacing a backlight: http://home.comcast.net/~stonent/screenfix.htm If you aren't comfortable taking things like this apart, I would recommend finding a local repair shop to replace the backlight.
Feb 15, 2007 | Dell E173FP 17" LCD Monitor
Dell E2210 22" Widescreen Flat Panel Monitor Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
