Question about GE WWSE5200B Top Load Washer
How do you take the cover off of a GE model wdsr2080d5ww
  • 867 Answers
Standard way is to remove all screws around the top cover, including the ones by the lint filter, then prying from the front with a little force as most units have spring clips at the front, and hinge clips at the back
Posted on Jun 14, 2009
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Posted on Jun 12, 2009
Model wdsr2080d5ww
this model does not have a accsesibale lint filter
Jan 27, 2014 | GE WWSE5200B Top Load Washer
GE WDSR2080D5WW wont spin or agitate
The coupling might be bad. Take cabnet off by removing 2 screws from counsel, then flip up and pop 2 clips and the cabnet will pull away from machine. Then pop 2 clips off pump down in front of machine then take the 2 quarter inch screws out of the 2 clips holding motor then you'll see coupling. Any questions call Chris's r Repair at 716-258-1944
Dec 21, 2011 | GE WDSR2080D Top Load Washer
GE WDSR2080D5WW will not spin.
One of them support rods is probably broken
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | GE WDSR2080D Top Load Washer
My wdsr2080d5ww GE is overfilling and never stops.
Bad water level switch or hose to switch is damaged or unhooked. You should be able to find a diagram at www.appliancepartspros.com as well as get any parts you need.
Dec 30, 2009 | Washing Machines
Model#wdsr2080d5ww serial#rg118515g worked fine until yesterday, leaking water on floor at front left [about a quart] same today, tipped over,took back off,no wet areas.pieces of insulation at bottom. What...
Should be able to remove front while it's standing in place. If there's not two screws on the front bottom, it will have two push clips about a third of the way in on either side between top and front. Push in gently with a standard screwdriver on the clip while tugging on top corner of front.
Nov 17, 2009 | GE WDSR2080D Top Load Washer
Jun 11, 2009 | GE WDSR2080D Top Load Washer
GE Mod WDSR2080D5WW won't drain
The last one I repaired had a 2 quarters in the pump.
Remove the hoses and inspect the pump for coinage.
Feb 03, 2009 | GE WDSR2080D Top Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
GE WWSE5200B Top Load Washer Logo
533 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
