Question about Fisher Digital New Tablet Pc Android 2 With Camera For Video Chatting 7 4 Inch
My Fisher Digital Tablet 7.1 wont charge. Checked charger works ok just not on tablet
Blank screen when plugged in. will show an empty battery then shut off
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
Tablet turns on and then shuts down right away
Your tablet is not charging , those are the symptoms of an empty battery
Mar 17, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
I am trying to charge this tablet. After hours, it is still showing an empty battery when I try and turn it on.
Check its charger first. If there is no power output from the charger, the battery won't charge. If it is found OK, surely the battery inside your tablet is bad; should be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 07, 2014 | Latte Android 4.2 7 HD Screen Dual Core...
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
My tablet wont work at all
all I cant suggest if its still under warranty take it back to place of purchase,my flatmates boy had same problem the guy at the shop where it was brought from fix it in about 2minutes and no charge .
Jan 17, 2014 | Nextbook Premium 7 Capacitive Touch...
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Fisher Digital New Tablet Pc Android 2 With Camera For Video Chatting 7 4 Inch Logo
Top Fisher Digital Tablets & eReaders Experts
Are you a Fisher Digital Tablet and eReader Expert? Answer questions, earn points and help others
